Old 06-19-2020, 12:16 PM   #1
RG4L
Question Exhaust line and Back Pressure
Im getting a Full Blown stage 1 turbo kit which runs an over pipe with 3” of diameter, but I cant find a frontpipe that has a high flow cat at 3”, so I was gonna either:
- Run the front pipe at 2.5 and continue the line at 3”
- Continue the whole line from the front pipe at 2.5
- or keep my borla cat back that goes from 2.5 to 2 and get a 2.5 front pipe
Im just wondering if running any of does lines 7-8 psi will create to much back pressure...
RG4L is offline   Reply With Quote
Old 06-19-2020, 12:53 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
JDL makes 3" front pipe with high flow cat. You can get an Avo 3" with high flow cat. Google is a wonderful tool my friend.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
The Following 3 Users Say Thank You to Joveen For This Useful Post:
DarkPira7e (06-19-2020), Irace86.2.0 (06-19-2020), RG4L (06-19-2020)
Old 06-19-2020, 01:02 PM   #3
RG4L
Im dumb asf, for some reason google didn’t show me the jdl one but I went to the website and I see it now thanks bro. Do y’all think it should ve resonated or not
Old 06-19-2020, 01:28 PM   #4
Joveen
Joveen's Avatar
Drives: Bone stock
Up to you. Catted and resonated will definitely keep it quiter and deep toned. Dual resonated will definitely deepen the sound and keep it mildly quiet. I say dual resonated as it basically catless without drone and will make it sound better and keep cabin vibrations and drone down.
Old 06-19-2020, 01:47 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's as Joveen says. But keep in mind, if you do an open dump wastegate ( not recirculated) none of your exhaust system will be deadening that sound. it's like a second exhaust that is about 6" long and it SCREAMS, but is only open when the wastegate opens (hopefully around your set boost level)
Look up videos of " open dump wastegate" to understand what I'm referring to.
RG4L (06-19-2020)
Old 06-19-2020, 01:57 PM   #6
RG4L
That’s exactly the tone im looking for, especially cause I dont want a raspy exhaust overtaking the turbo noise. But I will have to do a resonated and cat cause the full blown kit looks like only does uncatted equal length headers
The Following User Says Thank You to RG4L For This Useful Post:
Joveen (06-19-2020)
Old 06-19-2020, 02:28 PM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Do recirculated or else you will sound like an obnoxious, screaming banshee.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 06-19-2020, 02:44 PM   #8
RG4L
Lmao Thats exactly what I dont want. So recirculated turbo and the two resonators. Will that sound like a honda?
Old 06-19-2020, 02:55 PM   #9
Irace86.2.0
I hope not.
Old 06-19-2020, 02:58 PM   #10
DarkPira7e
DarkPira7e's Avatar
I just uploaded this video so you can hear an example. My car has the open wastegate dump, but a stock exhaust.
If I had a recirculating exhaust, it wouldn't be very loud at all, but outside the car the noise can be heard very very far away. My car has an equal length header as well, which is more " honda" than you'll get with an unequal length header.
RG4L (06-19-2020)
Old 06-19-2020, 03:11 PM   #11
RG4L
That sounds awesome!! Did you modified anything in particular to get that “tututu”
Old 06-19-2020, 03:17 PM   #12
DarkPira7e
DarkPira7e's Avatar
I have no blow off valve, the port is completely blocked off. So the air that is supposed to escape cannot. I was running it like that to test and ended up leaving it like that, I had no negative effects but I did not run it like that for more than a few months. I have no data to suggest whether or not it will harm the turbo compressor, so I would not recommend it until I can prove without a doubt that it would not harm something.
Old 06-19-2020, 04:32 PM   #13
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
this is a dumb question and partially jacking the thread but do they even make headers with 3" exits for super charged engines?
Old 06-19-2020, 06:57 PM   #14
DarkPira7e
DarkPira7e's Avatar
Fairly certain Nameless makes headers that are 3" where it meets the overpipe. Doesn't really matter, since you can just get a 3" overpipe and it'll go from 2.5" at the header to 3" at the overpipe.
Adding in line fuel pressure regulator KGZ86 Engine, Exhaust, Transmission 13 07-07-2016 05:15 PM
Axle back exhaust feed back requested Gruppe-s Engine, Exhaust, Transmission 10 12-10-2014 07:56 PM
Back Pressure kalamitykode Engine, Exhaust, Transmission 24 11-16-2014 11:34 PM
exhaust sizing and back pressure some facts on the debate cdrazic93 Engine, Exhaust, Transmission 0 10-02-2014 02:21 PM
Not enough exhaust Back Pressure? Quiet car? mtimney Engine, Exhaust, Transmission 11 08-05-2013 11:10 PM
