Drives: 2013' Toyota 86 (EU spec)
Fuel tank capacitiy: Level vs. Volume Table
Hi all,
can anyone help me out with a level (or even better sender voltage) vs volume table? I did a LS swap on my 86 using the OEM GM E38 ECU and am trying now to dial in the correct fuel volume left per sender level. Of course the tune I use (from a Camaro) is set to a different volume und shape of the tank. On the GM side of the ECU tune world there are tables for primary and secondary level sensor. I´m not familiar with the Toyota side of this topic, but I´d like to assume that there should also be some kind of a table for that... Unfortunately TIS only tells you max and min level sender resistance. No information about anything in between and so with no respect to the corrsponding volume. Thanks in advance! |
Drives: brz
I seem to recall, reading that the Empty to full was calculated between 1/4 readings then displayed. Other words the ecu only reads in 4 spots, then calculates between those.
Not for sure though. |
| DIY : Draining the gas tank - Methods to empty fuel tank | Mermoz | DIY (Do-It-Yourself) Guides | 13 | 10-09-2025 02:56 PM |
| UEL headers sound level (volume) | Xbk47 | Engine, Exhaust, Transmission | 15 | 12-11-2021 01:31 AM |
| E85 tune what table inceases fueling volume | ROADRACER | Software Tuning | 8 | 09-20-2016 11:10 AM |
| FRS/BRZ Volume level | Scionguy28 | Electronics | Audio | NAV | Infotainment | 7 | 12-03-2014 07:31 AM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 03:39 PM |
