Old 11-22-2014, 04:28 PM   #1
Scionguy28
Scionguy28's Avatar
Drives: Scion FR-S 10 Series
FRS/BRZ Volume level
As we all know the volume of the FRS/BRZ radio is really low, I was wondering if anyone had any ideas on how to increase the volume level? A new amp? a new head unit?
Scionguy28 is offline   Reply With Quote
Old 11-22-2014, 05:32 PM   #2
Oakhenshield
Oakhenshield's Avatar
Drives: ahh its blue?
i dont know for you but mine is loud enough for me i maxed my bass tho and some treble
Bruuuum Bruuuum!
Oakhenshield is offline   Reply With Quote
Old 11-22-2014, 06:04 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I haven't owned my car very long, but I think the problem isn't so much that the radio doesn't get loud enough, but more that the car itself simply suffers from a lot of road noise (nature of the beast.) In my last vehicle, a bit of aAmplifier made a world of a difference in both the volume and quality of the sound. Applying some CLD and MLV in key areas of this vehicle would be a good way to increase the sound quality and volume while simultaneously reducing road noise. I plan on doing this in the spring (or sooner if I get impatient or bored.)
Stang70Fastback is offline   Reply With Quote
Old 11-23-2014, 12:42 AM   #4
Poodles
I found the speakers took some time to break in. Sounded pretty crappy to begin with, but much better now.
It's always been loud enough though. Then again, I'm not one to listen to music at levels that damage my ears...
Old 11-23-2014, 01:35 AM   #5
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
Plug up the sound tube, for starters.
Candlejack is offline   Reply With Quote
The Following User Says Thank You to Candlejack For This Useful Post:
Mr.Impreza (11-26-2014)
Old 12-01-2014, 01:48 PM   #6
AtlasMick
Drives: FR-S 2013 Asphalt
If you are powering aftermarket amp for bass off of the stock headunit, mine starts clipping anywhere between 33-44 on some songs and is clipping constantly on all but the weakest bass songs after 44. Just something to think about, also the low level output voltage is very low, less than 1V at peak.
AtlasMick is offline   Reply With Quote
Old 12-01-2014, 02:32 PM   #7
swarb
There is a +/- setting in the options so you can set loudness levels for different inputs. You could also +/- the equalizer settings.
Old 12-03-2014, 07:31 AM   #8
mid_life_crisis
Drives: FR-S 10 #103 AT
Different H/U in the two cars. I have the same as the o/p and can't find this.
Volume of mp3 playthrough FRiSson Electronics | Audio | NAV | Infotainment 0 06-12-2014 01:27 PM
Operation buzzer volume Turbo95eg6 Electronics | Audio | NAV | Infotainment 3 04-27-2014 01:37 PM
Exhaust volume twag4 Engine, Exhaust, Transmission 17 09-24-2013 04:12 PM
Brake fluid volume celica73 Tracking / Autocross / HPDE / Drifting 1 08-20-2012 02:05 PM
Fluctuating volume so26 Issues | Warranty | Recalls / TSB 9 08-16-2012 12:26 AM
