Drives: 86 GT
Checking for ECU tune - List of good CVNs for CALIDs?
I'm trying to see if my car came with a tune. Reading posts especially from @steve99 says that I will have to compare my CALID and CVN both which I can get from an OBD2 tool. If the CVN is not from a known good value it indicates that the ECU has been tuned/tampered.
The only problem is - does a list exist of all CALIDs to known CVNs? Tried googling to look for one but there isn't any... |
#2 | |
i dont have list but if you read the tune from ecu you can compare it to a stock rom |
| The Following User Says Thank You to steve99 For This Useful Post: | Compelica (06-16-2020) |
Drives: brz 2017 hksv2
or do a log with valuable data we should be able to spot a stock tune
| The Following User Says Thank You to tomm.brz For This Useful Post: | Compelica (06-16-2020) |
#4 | ||
Drives: 86 GT
usually cams get changed, also afr target/actual, and maf voltage and mass air flow g/s
we can look then if they match the stock tune |
If you have a friend with same ecu calud you could check CVN against that if its stock
#7 | |
Drives: 86 GT
![]() I could only log from Torque though, which I could only get the AFR target / actual, MAF (g/s) and timing advance. Just realised that Torque does have an option to view the CVN, but when it's connected to my car the option is goes missing. |
can t look at it from phone
you should upload the csv to datazap. me thanks |
#9 | |
Drives: 86 GT
https://datazap.me/u/compelica/norma...data=0-1-2-3-4 |
#10 |
There is small check to tick, your kept the log private
so please go to Edit log and make it public |
#11 |
Drives: 86 GT
#12 |
too few data, not even Engine speed.. sorry
#13 |
Drives: 86 GT
Sorry @tomm.brz I can get you the other info... I was under the assumption you needed only those columns that you stated earlier.
Is there anything else you require other than engine speed? |
#14 |
intake and exhaust cam will help
also flkc and knock corr, usually it gets reduced tova minimum of -0,7 instead of -1 as minimum correction injection angle if available, try to put many things, i dont know how torque works |
| Looking for a good tune socal | Blitz_86 | Software Tuning | 2 | 02-13-2019 11:20 AM |
| The just checking in everything is good thread | go_a_way1 | Issues | Warranty | Recalls / TSB | 69 | 03-28-2016 10:04 PM |
| Good tune? | Romiikr | Software Tuning | 7 | 12-20-2015 07:33 PM |
| Perin CAI W/O tune! good or not ? | JdelFrs | Software Tuning | 8 | 03-05-2014 11:33 PM |
| Will this be a good decade for car enthusiasts? (huge list of cars) | RaceR | Other Vehicles & General Automotive Discussions | 36 | 11-05-2012 05:53 PM |
