Old 06-16-2020, 02:17 AM   #1
Compelica
Compelica's Avatar
Drives: 86 GT
Checking for ECU tune - List of good CVNs for CALIDs?
I'm trying to see if my car came with a tune. Reading posts especially from @steve99 says that I will have to compare my CALID and CVN both which I can get from an OBD2 tool. If the CVN is not from a known good value it indicates that the ECU has been tuned/tampered.
The only problem is - does a list exist of all CALIDs to known CVNs? Tried googling to look for one but there isn't any...
Compelica is online now   Reply With Quote
Old 06-16-2020, 04:27 AM   #2
steve99
Drives: FT86
i dont have list
but if you read the tune from ecu you can compare it to a stock rom
Compelica (06-16-2020)
Old 06-16-2020, 06:34 AM   #3
tomm.brz
Drives: brz 2017 hksv2
or do a log with valuable data we should be able to spot a stock tune
Old 06-16-2020, 11:55 AM   #4
Compelica
Compelica's Avatar
Drives: 86 GT
i dont have list
I don't have any specialized tools though, only a generic cable for use with Techstream and an Bluetooth OBD2.
What would I need to log? I can put it here
Old 06-16-2020, 02:50 PM   #5
tomm.brz
usually cams get changed, also afr target/actual, and maf voltage and mass air flow g/s
we can look then if they match the stock tune
Old 06-16-2020, 11:21 PM   #6
steve99
Drives: FT86
If you have a friend with same ecu calud you could check CVN against that if its stock
Old 06-17-2020, 11:39 AM   #7
Compelica
Compelica's Avatar
Drives: 86 GT
@tomm.brz I've attached a zip of the log here, from a warm start towards a highway and traffic congestion near the end. Appreciate it
I could only log from Torque though, which I could only get the AFR target / actual, MAF (g/s) and timing advance.
Just realised that Torque does have an option to view the CVN, but when it's connected to my car the option is goes missing.
Old 06-17-2020, 03:24 PM   #8
tomm.brz
can t look at it from phone
you should upload the csv to datazap. me thanks
Old 06-17-2020, 10:29 PM   #9
Compelica
Compelica's Avatar
Drives: 86 GT
Uploaded here:
https://datazap.me/u/compelica/norma...data=0-1-2-3-4
Old 06-18-2020, 01:50 AM   #10
tomm.brz
There is small check to tick, your kept the log private
so please go to Edit log and make it public
Old 06-18-2020, 02:14 AM   #11
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks for pointing it out - changed the setting to Public now.
Also, calibration ID is ZA1JF00A if that helps.
Old 06-18-2020, 03:05 AM   #12
tomm.brz
too few data, not even Engine speed.. sorry
Old 06-18-2020, 04:20 AM   #13
Compelica
Compelica's Avatar
Drives: 86 GT
Sorry @tomm.brz I can get you the other info... I was under the assumption you needed only those columns that you stated earlier.
Is there anything else you require other than engine speed?
Old 06-18-2020, 07:50 AM   #14
tomm.brz
intake and exhaust cam will help
also flkc and knock corr, usually it gets reduced tova minimum of -0,7 instead of -1 as minimum correction
injection angle if available, try to put many things, i dont know how torque works
Looking for a good tune socal Blitz_86 Software Tuning 2 02-13-2019 11:20 AM
The just checking in everything is good thread go_a_way1 Issues | Warranty | Recalls / TSB 69 03-28-2016 10:04 PM
Good tune? Romiikr Software Tuning 7 12-20-2015 07:33 PM
Perin CAI W/O tune! good or not ? JdelFrs Software Tuning 8 03-05-2014 11:33 PM
Will this be a good decade for car enthusiasts? (huge list of cars) RaceR Other Vehicles & General Automotive Discussions 36 11-05-2012 05:53 PM
