Drives: Full HKS GT86
Ecutek - Using rear 02 for a different sensor
As per title, I am using the rear 02 sensor for a oil pressure input. All ok but I can see the voltage feed to the sensor which I am taking from the rear 02 osciliates. Reading around it's because I am using the o2 heater to power the sensor and this uses PWM to cycle the heater on and off normally.
If I power the sensor from a direct feed to the battery it works as expected. Does anyone know how I can power the sensor without this PWM / voltage oscillation? Is there a way I can turn it off in Ecutek? I can see other people have run the oil pressure sensor solely off the rear 02 socket so I know it's possible. Sent from my SM-G950F using Tapatalk |
| The Following User Says Thank You to Dom2497 For This Useful Post: | nerve86 (10-03-2022) |
Drives: brz 2017 hksv2
i do this: Do not use custom map for that
Use Ecutek COOLANT PRESSURE (CP) sensor you can scale your sensor there and apply SMOOTHING put a smoothing of 0.2 (1 is no smoothing) and you ll have your output value much more stable and then with custom map you will refer to COOLANT PRESSURE to build a failsafe if you want if you need help i can do it for you, otherwise ask your tuner to use the CP same signal of oil pressure from rear 02, one with smoothing one without ![]() edit: sorry didn t read well. you should NOT power your sensor with rear o2, you need a stable 12v possibly on key, change it ASAP Last edited by tomm.brz; 06-14-2020 at 07:21 AM. |
#3 | |
#4 | |
| The Following User Says Thank You to Dom2497 For This Useful Post: | tomm.brz (06-15-2020) |
| Omni 3bar map sensor values for ecutek | Agent_D | Software Tuning | 9 | 07-17-2017 09:32 PM |
| Rear parking sensor | Eighty 6 | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-06-2016 11:05 PM |
| WTB: OEM Rear Oxygen (o2) Sensor | xjohnx | Want-To-Buy Requests | 5 | 04-07-2014 10:32 PM |
| Ecutek Map Access, data logging Vs. obd2 sensor | lbroskee | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 01-06-2013 02:56 PM |
