Old 04-30-2016, 05:00 PM   #1
Agent_D
Omni 3bar map sensor values for ecutek
Wondering if anyone can provide the values I need to install the Omni 3bar sensor with an ecutek. I've been searching for days with no luck. Thanks for the help!
Sent from my D6708 using Tapatalk
Agent_D is offline   Reply With Quote
Old 04-30-2016, 05:44 PM   #2
steve99
Use at own risk :-)
MAP Scalings for Alternative MAP sensors for Boosted cars (Manifold Pressure Sensors)
Omni 2.5 Bar MAP
The OFT300 (Vortex supercharger) map uses the 2.5 BAR Omni and has CEL-P0068 disabled in the map
ok for 2.5 Bar OMNI MAP sensor ECUTEK scaling in BAR
Manifold Pressure Sensor multiplier in bar per volt. = 0.500
Manifold pressure sensor offset. Value is measured in bar. = 0.100
MAP Sensor voltage max = 5.0v
MAP sensor Voltage min = 0.0v
Omni 3 Bar MAP Sensor (Metric in Bar)
0.617 - MULTIPLIER
0.03 - OFFSET
scaling limits 0 - 4.75v
Omni 4 Bar MAP Sensor
Manifold Pressure Sensor Scaling - (imperial PSI)
Multiplier - 12.087
Offset - 0.168
Metric/Bar
bar/volt .833
offset (bar) .012
Manifold Pressure Sensor Limits - (CEL still comes on )
High Input CEL Above - 5.00v
Low Input CEL Below - 0.00v
Disable CEL P0103 and P0068
Old 04-30-2016, 05:52 PM   #3
Agent_D
Thank you!
Old 05-30-2017, 04:23 PM   #4
srscion
srscion's Avatar
Drives: 2016 FRS
Use at own risk :-)
Omni 2.5 Bar MAP
0.617 - MULTIPLIER
0.03 - OFFSET
Multiplier - 12.087
Offset - 0.168
Metric/Bar
bar/volt .833
offset (bar) .012
The offset for the Omni bar3 is supposed to be 11
The offset for the Omni bar4 is supposed to be 31
srscion is offline   Reply With Quote
Old 05-30-2017, 06:25 PM   #5
steve99
Is that in bar or psi ?
Old 05-30-2017, 07:57 PM   #6
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I haven't had to disable the CEL...
Use at own risk :-)
Omni 2.5 Bar MAP
0.617 - MULTIPLIER
0.03 - OFFSET
Multiplier - 12.087
Offset - 0.168
Metric/Bar
bar/volt .833
offset (bar) .012
I've been running the omni 3bar and haven't had to disable any CELs so far. I've ran it for a couple of months.
Jaden
Jaden is offline   Reply With Quote
Old 06-11-2017, 10:25 AM   #7
aquaman
aquaman's Avatar
Do you mean .11 and .31 or 11 and 31?
aquaman is offline   Reply With Quote
Old 07-13-2017, 07:45 PM   #8
srscion
srscion's Avatar
Drives: 2016 FRS
Sorry for the long reply, this is directly from the Omni power website . there is no information regarding if it's metric or not unfortunately I'm still trying to track down what the proper conversion would be
Old 07-13-2017, 07:47 PM   #9
srscion
srscion's Avatar
Drives: 2016 FRS
Jaden
What values did you use?
Old 07-17-2017, 09:32 PM   #10
aquaman
aquaman's Avatar
.03
WTB: 3-Bar OMNI Map Sensor FR-S Matt Want-To-Buy Requests 0 06-18-2014 12:14 PM
Front Oxygen Sensor Scaling - How do we make it read richer values? D-VO Software Tuning 7 05-08-2014 04:48 AM
Omni 4 Bar Map Sensor New Cross Engine, Exhaust, Bolt-Ons 3 04-06-2014 02:31 PM
FS: NIB OMNI 4 BAR MAP Sensor woode Engine, Exhaust, Bolt-Ons 3 04-04-2014 11:19 AM
FS: NY - Omni 3 Bar Map Sensor xxscaxx Engine, Exhaust, Bolt-Ons 7 03-11-2014 11:41 AM
