Old 06-02-2020, 08:56 AM   #1
Ohio Enthusiast
Drives: 2018 BRZ
Steering rack bushing fit for 2017+ Twins?
I'm looking at steering rack bushings (probably the Energy Suspension ones), but all places list them as compatible with up to 2016 (sometimes even less). Is that just an omission in the specs or was there a real change in the steering rack bushings in the facelift?
Ohio Enthusiast is offline   Reply With Quote
Old 06-02-2020, 09:57 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I used the diftech 10589 in my 2020, and its listed for 2013-2017 models.
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
Ohio Enthusiast (06-02-2020)
Old 06-02-2020, 01:33 PM   #3
Jdmjunkie
Drives: Scion FR-S 10 Series
I am getting super pros installed in the next week or so. I have their diff and trans bushes. They are extremely well made and engineered, and I have noticed no increase in NVH.
Jdmjunkie is offline   Reply With Quote
Old 06-02-2020, 02:04 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Or maybe you were trying to detect different portion of NVH, which stands not just for noise and harshness, but also vibration. From my experience (using perrin's steering rack lockdown though), there is slight increase of vibrations passed from road to steering wheel. It is also as extra feedback though, and those more vibrations weren't ever to level of being tiring or annoying, even during very long drives, so that NVH change that there is can be ignored imho.
Old 07-08-2020, 11:07 AM   #5
Ohio Enthusiast
Drives: 2018 BRZ
To confirm - I installed Energy Suspension bushings (8.10105G) on my 2018 BRZ and had no fitment problems. For the curious, I used a DIY version of the Cusco bushing removal tool using a short piece of 2" PVC pipe and a 3/8" threaded rod with some nuts and washers. A big c-clamp was helpful as well to press the old bushing out all the way and press the new bushing in (the outer poly part slides in by hand, but the inner metal part needs to be pressed in).
Old 07-08-2020, 12:46 PM   #6
dragoontwo
dragoontwo's Avatar
I just used a socket and a crappy 2 jaw puller.
Ohio Enthusiast (07-08-2020)
Old 07-08-2020, 01:00 PM   #7
Ohio Enthusiast
Drives: 2018 BRZ
Yeah, gotta use what you have on hand. I didn't have a socket big enough and no jaw puller (crappy or otherwise).
Old 07-09-2020, 08:30 AM   #8
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
If you can find a socket or a short piece of 1 1/2 of pvc pipe, a 6" long 1/2 or 3/8 carriage or hex bolt with a nut and and fender washer will pop the factory bushings right out.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Ohio Enthusiast (07-09-2020)
DIY: Turn In Concepts Solid Aluminum Steering Rack Bushing Install (and review) Sithspawn DIY (Do-It-Yourself) Guides 38 08-10-2018 11:07 AM
Steering Rack bushing torque spec please sroby Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-31-2017 06:40 PM
Turn in Concepts Steering Rack Bushing review Dave-ROR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 04-26-2015 07:48 AM
Steering rack bushing weekend sale Turn in Concepts Brakes, Suspension, Chassis 0 05-17-2013 07:24 PM
TIC Solid Steering Rack Bushing's Track Review track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-17-2013 01:24 PM
