Old 06-01-2020, 07:58 AM   #1
jeffs42885
Drives:
Wheel newb- need suggestions for first time purchase
So let me begin my saying I am a complete newb when it comes to Fitment.
I just picked up my 2015 RS, and I want to get wheels for it. It has XXR’s and 205 series hannooks. The tires have somewhat of a stretch and I don’t like it.
I’m looking to buy a high quality wheel and tire setup; around the $1600-1800 mark. Good tires and a good wheel. First question
What wheel size and tire size should I go for. Looking for best Fitment and handling.
Second question - where is a good place to buy a complete setup. Wheels. Tires. Tire sensor monitors.
Thanks in advance as always
jeffs42885 is offline   Reply With Quote
Old 06-01-2020, 08:38 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Do you know what size and offset the XXRs are? You could just get tires to fit them...
Tire Rack is a decent resource for wheel/tire packages:
www.tirerack.com
Old 06-01-2020, 08:53 AM   #3
Chuckable
Drives: 2017 Toyota 86
Yes, Tire Rack is a go to place for wheels and tires. Discount Tire Direct is also pretty common. Fitment Industries is another one.
Other vendors, like Apex, will sell you wheels and tires, too.
If you’re set on getting new wheels, first decide what diameter you want, and then width and offset. That will narrows your wheel choices down.
If you want a “high quality” wheel and tire package for your budget then 17” wheels are probably your best bet.
Chuckable is offline   Reply With Quote
Old 06-01-2020, 08:57 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Can you get us photos? I've run and seen people run XXRs, nothing really wrong with them if you're not tracking the car or purposefully hitting hard pot holes.
As others have said, if you like the style of the wheel, just get wider tires. I'd expect an XXR on this platform to be in an 8.75" width probably, but there's no way of knowing without taking the wheel off and looking for the specs printed on the back.
Old 06-01-2020, 10:06 AM   #5
Vital
Drives: 2015 BRZ
For a "high quality" setup and your budget you should consider Weds TC105X in 17x9 with a 245/40/17 tire size
Vital is offline   Reply With Quote
The Following User Says Thank You to Vital For This Useful Post:
Plumbus (09-19-2020)
Old 06-01-2020, 08:38 PM   #6
Chuckable
That would be a great setup for sure, but beyond the budget OP mentioned.
The Following User Says Thank You to Chuckable For This Useful Post:
Vital (06-02-2020)
Old 06-02-2020, 09:22 AM   #7
Vital
Drives: 2015 BRZ
He could try messaging Gruppe-S and see what kind of discounted price they offer for those wheels + cost of tires he might be near or slightly over his suggest budget.
OP message this vendor in this thread.
https://www.ft86club.com/forums/showthread.php?t=131771
Old 06-02-2020, 10:06 AM   #8
86MLR
86MLR's Avatar
I would be focusing on what size tyre you want to run, then look at the rims.
Also think about if you want a bbk later on down the track.
Tyres are the performance, rims are for connecting the tyres to the car, and typically more often than not, the look.
For a NA twin street car on avererage streets and roads you cannot go past 17 x 215 - 225 tyres, sooo... a 17" x 8" rim, so.......I would be looking at the best tyres you can budget for in that range.
Plus the 17 x 215 - 225 tyres are typically much cheaper than a 18 or larger with the typical width.
If you want more meat, a 17 x 235/40 works well and gives a mix of good comfort and performance.
18" will start compromising comfort, 19" will be rubbish for anything other than dead smooth roads.
In the end the car isn't a power house, over tyring a car will remove alot of the playfulness and fun you can have at legal speed limits.
Plus the bigger the rims and tyres, typically the more unsprung weight you have.
Opinions may vary
Function
Form
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
candygram4mongo (09-18-2020), Spuds (06-02-2020)
Old 06-02-2020, 07:09 PM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Wheels:
Stick with a 17x7 or 17x8 if you really want to go wider. Keep offset as close to stock as possible or you will mess up your effective spring and damping rates. Obviously keep it 5x100. Other than that, there's the style/cost/weight trade off to consider. Weight is an important consideration. I recommend tirerack.com for wheel shopping.
Tires:
Look for articles on tirerack.com and do your research as to what performance level of tires you think you want. Plenty of comparisons and technical info there. As for size, that depends on the size of the wheel. Both 215/45 and 225/45 work on 17x7 wheels I can tell you that much. Again, style/weight/performance/cost play important factors and those differ with taste.
The Following User Says Thank You to Spuds For This Useful Post:
why? (06-07-2020)
Old 06-05-2020, 06:27 AM   #10
BRZ_88
Imperator
Drives: Supercharged 2013 BRZ Limited
I found this tool really useful for checking fitment. It gives you a good visual reference for comparing offsets.
https://www.ft86motorsports.com/wheelitfit/
Also don't forget to pick up some hubcentric rings if your new wheels have a centerbore larger than 56mm.
BRZ_88 is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZ_88 For This Useful Post:
Busybee (06-05-2020), soundman98 (06-05-2020)
Old 06-06-2020, 05:08 PM   #11
jeffs42885
Drives:
Thanks for the feedback folks. I’m thinking a set of option lab R555, 18x9.5 on 255 firestone Indy 500s
What’s the best place to source these.
Old 09-17-2020, 01:43 AM   #12
HaXx
Drives: jrsc_brz
Just gonna throw a curve ball and recommend buying used. You can get a crazy nice set of enkei's with good tires for $1k. Tire rack is great for new. Dont knock ebay either when looking new either. But theres plenty of great used sets out there find your local group on Facebook. I just sold a 1y/o set of enkei's for $1000
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 09-19-2020, 11:45 AM   #13
Racecomp Engineering
No one here recommended anything like that. It's not a great idea.
Do you want your car to handle well?
What suspension are you planning on running?
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
x808drifter (10-08-2020)
Old 10-08-2020, 03:11 AM   #14
Bezzos
Drives: Black
Any suggestion for tire and wheel packages perfect for my Subaru BRZ? I am choosing between Nitto Neo Gen and Michelin Pilot Super Sport. Which brand is the right fit for my car?
Bezzos is offline   Reply With Quote
Tax return time = WHEEL CLEARANCE TIME from Gram Lights and Yokohama vividracing Wheels and Tires 4 04-04-2014 02:46 PM
Help with wheel purchase mystic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-06-2014 09:30 PM
Help a first-time aftermarket wheel customer with questions before purchase! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-02-2013 03:59 PM
wheel/tire purchase help sitandspin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-18-2012 12:08 AM
If you want to PURCHASE an 18" S7 wheel post here. Memphis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-31-2012 03:49 PM
