Drives: Subaru BRZ S 2013
Help preparing for Forced Induction
Hi all,
Just looking for some collective advice for preparation in going with turbocharged forced induction. Have already installed MCA Purple coilovers to fit wider rims and tyres on the car for more grip with the additional power. What components of the exhaust are necessary to have prior to FI for the best gains? (OP/FP/Catback?) What are the preferred oil cooling kit brands? As i plan to run E85 Flex Fuel, what size injectors should i be looking to install? Is a new fuel pump absolutely necessary? I am wanting to collect as many of these items as possible prior to tuning the car with the turbo installed, as dyno tunes aren't cheap. Any constructive advice would be great, Cheers. |
Drives: Crapcan
You should be communicating your goals with your tuner. When I was going to go FI the first thing I did was contact a known local tuner and ask questions.
#3 | |
Drives: 2017 toyota 86
Rust bucket enthusiast
Talk to tuner
#5 | |
Drives: Q5 + BRZ + M796
The best gains, aka the most power, will be straight piping the exhaust system with a catless header. My preference is the Jackson Racing radiator/oil cooler combo. Plenty of good oil coolers. Some have thermostatic plates or have other features for draining oil or whatever. ID 1050s are best. 770s are enough for most who don't have built motors, and a pump isn't necessary. I am on E85 @ 12psi with 770s. I got a pump just for insurance. You will need a clutch upgrade.
#6 | |
Drives: 2017 Subaru BRZ
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17 |
#7 | |
Drives: 2013 frs red
#8 | |
Drives: TRD R.S. 1.0 FRS
Concerned about the price of the tune because he wants to do it once, so yea if youre thinking he’s gonna tune multiple times, uhh dang thats some cash i guess. |
^good point
#10 | |
^^ this. What's the point of tuning every time i get a new part. Would rather do it all at once. |
#11 |
What system you using?
Power goals? Internet power points? Street only? Track only? Street and track? Do you have a budget for spare or upgraded gearbox if your going to "send it"? Same for stock engine? My 2017 86 made 270hpatw, AVO, 2.5" overpipe, stock decatted front pipe, stock cat back, stock airfilter, oil temps were fine with only a Forester heat exchanger. Clutch didn't slip either. What you use the car for will determine the additional required parts or upgrades. Talk to the guy who is going to tune the car, and by that I mean on a dyno, with a tuner who is actually good. Not all tuners are good, they all say they are though. Don't skimp out on the tuning, this is the most part of the build, both for power and, more importantly, reliability. Don't look for a big number, look for a tuner who will get the best out of your car with a safe and reliable tune. Enjoy
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#12 |
Yup, if youre dyno tuning all the more, they'll be more expensive since you'll need to schedule an appointment for time for the dyno and all that. I chose a E-tune with a well-known tuner. What really matter is the tuner is good, a dyno will always help with tuning, but if your tuner is actually good, shouldn't be the end of the world.
#13 | |
Imperator
Drives: Supercharged 2013 BRZ Limited
I opted for E85, if you want to go that route too you will need a new fuel pump and injectors. Injector size really depends on what turbo/SC kit you're running. I'm not sure what regulations are like where you are, but catless headers will give you a noticable power (and noise) increase, if that's not an option a hi flow cat will help too but they aren't cheap. After a lot of research I found that catbacks don't really do a lot for the money, I just got an axleback for the sound and weight saving. Tuning wise I got an Ecutek E tune through FT86. You send your tuner a full list of parts you're installing, then he'll give you a starting tune so you can send him logs and he'll tweak it until it's right. |
#14 | |
E tunes are decent, but the advantage in the dyno tuning is real time safety. If something wasn't working right, the tuner could notice right away. "Oh stop, it shouldn't be hesitating here" or "whoa hold up that afr is way lean" isn't possible when they just send a basemap and say "send it and hopefully you installed everything perfectly" |
| Forced Induction | James The Giant | Mid-Atlantic | 4 | 03-17-2017 12:00 PM |
| Most *fun* forced induction | bfrank1972 | Forced Induction | 45 | 12-22-2016 11:36 AM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 03:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 07:17 AM |
| 6AT (+) Forced Induction | RYU | Forced Induction | 18 | 09-09-2012 11:14 PM |
