Drives: 2017 Toyota 86
17x9 that checks all the boxes?
I’ve been looking for a wheel that checks all the boxes and was hoping the collective wisdom of the forum would help me with any wheels I’ve missed.
Here’s what I’m looking for: 17x9 Clears Stoptech ST40 calipers with 328x28mm rotors (similar in size to OEM Brembos) 20lbs or less Offset range of +38 to +42 Max of about $325/wheel Readily available in a silver, charcoal, gunmetal, silver or similar finish (because my car is black) Replacements somewhat easy to source So far I’ve found: Apex ARC8 ~ $240-$260/wheel 17.8lbs ![]() Enkei PF05 ~ $315-$360/wheel 20 lbs as best as I can tell ![]() SSR GTX01 (unknown brake clearance) ~ $350/wheel (center caps are extra $) 19lbs as best as I can tell ![]() Mach V Awesome $250/wheel 18lbs ![]() Rays 57CR (unknown brake clearance) ~ $320-$360+ (center caps are extra $) About 19lbs as best as I can tell HS Gunmetallic color is fairly hard to find ![]() Anyone know of anything else? Edit: I’m aware of 949 Racing 6UL and Konig but just don’t personally like the looks of them. Thanks! Sent from my iPhone using Tapatalk Last edited by Chuckable; 05-30-2020 at 07:09 PM. |
Drives: White BRZ Limited
hear me out.
I had Rota Titans. cleared my RR Racing stage 2 kit with Wilwood BBK. Used on the track, and great fitment with 255's |
| The Following User Says Thank You to Sgtfluffy16 For This Useful Post: | Chuckable (05-30-2020) |
#4 | |
I hear you. From what I’ve researched the early stigma against Rota wheels has largely dissipated. They look a lot like the Wedsport TC105N. Sent from my iPhone using Tapatalk |
I got so much shit from the all Mighty wheel gods who are on the Facebook groups about them. I had two sets of them, one set with track tires and the other set with street tires. I liked them, never had an issue with them, and actually about a pound lighter than the overplayed rpf1s
| The Following User Says Thank You to Sgtfluffy16 For This Useful Post: | DarkPira7e (05-30-2020) |
I’m open to all options that fit my list. Just want to learn about what’s out there.
Drives: Jeep 75th, Porsche GT3RS, BRZ tS
949 6ul
#9 | |
Drives: Crapcan
#10 |
Thanks. But I haven’t been able to find the 57DR in silver or gray?
#11 |
Wheels for Brains
57CR in HS Gunmetallic was an 86Speed color I believe, though I think by now other storefronts stock it (e.g. Kamispeed)
#12 | |
Thanks. I really like that style. But it’s out of stock everywhere I’ve checked and prices are $360+. Plus, no one has been able to confirm it will fit with the brake setup I have. Sent from my iPhone using Tapatalk Last edited by Chuckable; 05-30-2020 at 09:06 PM. |
#13 |
Drives: Crapcan
I am going to say it again. The 57DR CLEARS, so the 57CR should as well. If you want to double check this call a dealer that has both in stock in the same size and ask them how similar they are, as far as I can tell they are very similar and could even be same mold. The DR clears the ST40's by a lot, almsot 3/4's of an inch.
#14 |
Rust bucket enthusiast
I just bought a set of the ARC-8. Every color except silver seems to be on backorder from the manufacturer, just an FYI. Best looking wheel in my opinion
| SPC LCA's brand new in boxes: SOLD | bfrank1972 | Brakes, Suspension, Chassis | 4 | 10-26-2019 07:10 AM |
| ModBargains.com | What are in these boxes here? | ModBargains.com | Engine, Exhaust, Transmission | 7 | 02-20-2014 05:58 PM |
| Integrity Concepts boxes? | zooki | Electronics | Audio | NAV | Infotainment | 3 | 07-18-2013 03:13 PM |
| EOI - custom sub boxes group buy | nix | AUSTRALIA | 18 | 12-04-2012 03:12 AM |
| Creating custom sub boxes... | blackfireball5 | Electronics | Audio | NAV | Infotainment | 4 | 08-10-2012 04:54 PM |
