Old 05-30-2020, 03:03 PM   #1
Chuckable
Drives: 2017 Toyota 86
17x9 that checks all the boxes?
I’ve been looking for a wheel that checks all the boxes and was hoping the collective wisdom of the forum would help me with any wheels I’ve missed.
Here’s what I’m looking for:
17x9
Clears Stoptech ST40 calipers with 328x28mm rotors (similar in size to OEM Brembos)
20lbs or less
Offset range of +38 to +42
Max of about $325/wheel
Readily available in a silver, charcoal, gunmetal, silver or similar finish (because my car is black)
Replacements somewhat easy to source
So far I’ve found:
Apex ARC8
~ $240-$260/wheel
17.8lbs
Enkei PF05
~ $315-$360/wheel
20 lbs as best as I can tell
SSR GTX01 (unknown brake clearance)
~ $350/wheel (center caps are extra $)
19lbs as best as I can tell
Mach V Awesome
$250/wheel
18lbs
Rays 57CR (unknown brake clearance)
~ $320-$360+ (center caps are extra $)
About 19lbs as best as I can tell
HS Gunmetallic color is fairly hard to find
Anyone know of anything else?
Edit: I’m aware of 949 Racing 6UL and Konig but just don’t personally like the looks of them.
Thanks!
Chuckable is offline   Reply With Quote
Old 05-30-2020, 03:04 PM   #2
Chuckable
98-827-2430-01_FP.pdf
Here’s the Stoptech template
Old 05-30-2020, 06:34 PM   #3
Sgtfluffy16
Drives: White BRZ Limited
hear me out.
I had Rota Titans. cleared my RR Racing stage 2 kit with Wilwood BBK. Used on the track, and great fitment with 255's
Sgtfluffy16 is offline   Reply With Quote
The Following User Says Thank You to Sgtfluffy16 For This Useful Post:
Chuckable (05-30-2020)
Old 05-30-2020, 06:39 PM   #4
Chuckable
Originally Posted by Sgtfluffy16 View Post
hear me out.
I hear you. From what I’ve researched the early stigma against Rota wheels has largely dissipated. They look a lot like the Wedsport TC105N.
Old 05-30-2020, 06:52 PM   #5
Sgtfluffy16
I got so much shit from the all Mighty wheel gods who are on the Facebook groups about them. I had two sets of them, one set with track tires and the other set with street tires. I liked them, never had an issue with them, and actually about a pound lighter than the overplayed rpf1s
DarkPira7e (05-30-2020)
Old 05-30-2020, 06:55 PM   #6
Chuckable
I’m open to all options that fit my list. Just want to learn about what’s out there.
Old 05-30-2020, 07:06 PM   #7
Buteo
Drives: Jeep 75th, Porsche GT3RS, BRZ tS
949 6ul
Buteo is offline   Reply With Quote
Old 05-30-2020, 07:51 PM   #8
Chuckable
Originally Posted by Buteo View Post
949 6ul
Thanks. I updated the first post about that wheel. Just don’t like the looks too much. And when 949 confirmed that they are out of production, I took them off the lost.
Old 05-30-2020, 07:53 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
17x9
20lbs or less
The 57DR in that size clears so the CR should as well.
Old 05-30-2020, 08:13 PM   #10
Chuckable
Thanks. But I haven’t been able to find the 57DR in silver or gray?
Old 05-30-2020, 08:24 PM   #11
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
57CR in HS Gunmetallic was an 86Speed color I believe, though I think by now other storefronts stock it (e.g. Kamispeed)
EndlessAzure is offline   Reply With Quote
Old 05-30-2020, 08:37 PM   #12
Chuckable
Thanks. I really like that style. But it’s out of stock everywhere I’ve checked and prices are $360+. Plus, no one has been able to confirm it will fit with the brake setup I have.
Old 05-30-2020, 09:06 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am going to say it again. The 57DR CLEARS, so the 57CR should as well. If you want to double check this call a dealer that has both in stock in the same size and ask them how similar they are, as far as I can tell they are very similar and could even be same mold. The DR clears the ST40's by a lot, almsot 3/4's of an inch.
Old 05-30-2020, 09:10 PM   #14
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I just bought a set of the ARC-8. Every color except silver seems to be on backorder from the manufacturer, just an FYI. Best looking wheel in my opinion
SPC LCA's brand new in boxes: SOLD bfrank1972 Brakes, Suspension, Chassis 4 10-26-2019 07:10 AM
ModBargains.com | What are in these boxes here? ModBargains.com Engine, Exhaust, Transmission 7 02-20-2014 05:58 PM
Integrity Concepts boxes? zooki Electronics | Audio | NAV | Infotainment 3 07-18-2013 03:13 PM
EOI - custom sub boxes group buy nix AUSTRALIA 18 12-04-2012 03:12 AM
Creating custom sub boxes... blackfireball5 Electronics | Audio | NAV | Infotainment 4 08-10-2012 04:54 PM
