Drives: 2013 Scion FRS
Hello, first post. I have a 2013 Scion FRS and I recently had a motor swap. The engine has been running really rough and is currently running rich with a bunch of smoke burning out the exhaust. I suspect the problem is coming from the Oxygen sensors, but I need to know what the proper voltage specifications are for the Oxygen sensors? Does anyone know this info? Thanks.
Drives: Crapcan
The O2 and MAF operate in a voltage range. The only way to really test them is resistance across the pins at a specific temperature.
https://demos.starbase7.net/t3Portal..._rm_index.html Look under Engine/Hybrid System -> FA20 Engine Control and the inspection procedure for the Air fuel ratio sensor and the heated oxygen sensor. I doubt this is your issue though.
#3 | |
| Tags |
| engine, exhaust, frs, rough idle, sensors |
| Oxygen sensor cross threaded. | Zaneman | Issues | Warranty | Recalls / TSB | 13 | 07-05-2017 12:14 PM |
| DIY: Oxygen sensor spacer | Hardrock4445 | DIY (Do-It-Yourself) Guides | 13 | 07-11-2015 11:43 AM |
| WTB: Stock oxygen sensor | Njjawn | NY / NJ / CT / PA | 5 | 01-17-2015 03:53 PM |
| WTB: OEM Rear Oxygen (o2) Sensor | xjohnx | Want-To-Buy Requests | 5 | 04-07-2014 10:32 PM |
| fluid dynamics, venturi effect, and oxygen sensors. | EZWood | Engine, Exhaust, Transmission | 8 | 10-25-2012 06:21 AM |
