Old 10-24-2012, 06:46 PM   #1
EZWood
BAMF
EZWood's Avatar
fluid dynamics, venturi effect, and oxygen sensors.
I have a catless header and my downstream oxygen sensor has a spacer with a 90 degree bend. Anyone have any idea the angle in which the 90 should be facing in regards to the flow of exhaust gas that would decrease the reading on the oxygen sensor? Thanks
Old 10-24-2012, 07:37 PM   #2
serialk11r
Drives: '06 AM V8V Coupe
What do you mean "decrease the reading on the oxygen sensor"?
Old 10-24-2012, 08:51 PM   #3
mike2100
mike2100's Avatar
Drives: 23 BRZ
Got a picture of the spacer?
If it's what I'm picturing in my head, the orientation shouldn't matter. Venturi doesn't apply because there's no way for air that is outside the exhaust stream to enter the exhaust stream (except via the engine).
mike2100 is offline   Reply With Quote
Old 10-24-2012, 09:05 PM   #4
OrbitalEllipses
Drives: Attitude
On my WRX I just used two spark plug anti-foulers screwed into each other; one was drilled out to make room for the O2 sensor. Stock placement worked fine, never got a code.
Old 10-24-2012, 09:54 PM   #5
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
I think you mean to put a fouler?
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 10-25-2012, 12:09 AM   #6
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Wow... I had forgotten about this. Foulers... to think that we still need this.
soros151 is offline   Reply With Quote
Old 10-25-2012, 12:44 AM   #7
OrbitalEllipses
Drives: Attitude
Whatever they are you got the idea.
Old 10-25-2012, 01:42 AM   #8
EZWood
BAMF
EZWood's Avatar
I can take a picture tomorrow.
Old 10-25-2012, 06:21 AM   #9
mike2100
mike2100's Avatar
Drives: 23 BRZ
http://www.autozone.com/autozone/acc...er=730544_0_0_
anti fouler or non fouler is correct; they keep spark plugs from fouling due to failed rings
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 04:22 AM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 04:24 PM
Effect of shifter knob weight BMWDavid Engine, Exhaust, Transmission 3 08-03-2012 11:32 AM
MR-S Effect... Dimman CANADA 11 09-06-2011 11:49 AM
