Old 05-18-2020, 11:53 AM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
PP Brembo front rotor weight, lighter-weight alternatives?
Anybody know how much the factory BRZ PP Brembo front rotors weigh?
Apparently DBA 2-piece rotors weigh 21 lb., would like to know how much lighter than stock that is.
Any other lighter-weight rotor options for Performance Package Brembos?
Old 05-18-2020, 12:14 PM   #2
Racecomp Engineering
Approx 23 lbs for OEM
PFC has 2 piece rotors...17.7 lbs. Price is around $1k-ish (need to double check). We used to run these a lot on our older STI track cars.
These are the larger 2018+ 6 piston STI brembo rotors pictured below...same idea.
- Andrew
Old 05-18-2020, 12:27 PM   #3
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
I looked into this a while back while searching for BBKs for my old GC.
Take a look at the Girodisc 2-piece rotors. They're about $800 per pair. Lots of positive feedback from the STi owners over at IWSTi.
Weight measurement compared to stock rotors shown below (and link to thread). Keep in mind our PP rear rotors have different hats so the weight might be slightly off. But the fronts are the same as the 4-pot STi I believe:
https://www.iwsti.com/threads/2018-s...8/post-4447496
NaturallyAspirated is offline   Reply With Quote
Old 05-18-2020, 12:32 PM   #4
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I think the Girodisc 2-piece STi rotors will fit both front and rear for the Performance Package Brembos.
https://www.girodisc.com/Girodisc-Fr...i-_p_6545.html
https://www.girodisc.com/Girodisc-Re...Ti_p_5537.html
I think they are about 7 lbs lighter per side for the front and 3 lbs lighter per side for the rear.
Old 05-18-2020, 12:40 PM   #5
08+ STI rears will only fit if the hat is dual drilled for 5x100 and 5x114.
- Andrew
Old 05-18-2020, 02:36 PM   #6
Mike_ZN6
Mike_ZN6's Avatar
- Andrew
I am not familiar with the STi hub and rotor specs over the generations. Girodisc also has a rear rotor for the 04-07 STi. Maybe this one will fit the PP rears?
https://www.girodisc.com/Girodisc-Re...Ti_p_5527.html
Old 05-18-2020, 02:44 PM   #7
The trick is you need a "later" rear brembo but the later rear brembos for STI are all 5x114, although some aftermarket options are dual drilled with 5x114 and 5x100.
BRZ specific rear brembo rotors in 5x100 are harder to find but they do exist. I'm just not aware of any 2 piece options.
- Andrew
Old 05-18-2020, 04:03 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
So someone should buy batch of those later STI ones from whomever, custom drill 5x100 in own shop (or offer such service) and then sell at slight premium
Old 05-18-2020, 04:05 PM   #9
I mean Girodisc might even do it for you! We like the PFC front rotors but I have not tried Girodisc.
- Andrew
Old 05-18-2020, 04:40 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Thanks so much guys!
If the Gerodisc for '04-'17 fronts fit I might just get 'em. -11.6 lb. unsprung mass off the nose of the car, for *only* $800! Dayum...
Probably stick with 1-piece rears for now...
Old 05-19-2020, 06:32 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
GiroDisc site doesn't show BRZ fitments, but this site shows front and rear Girodisc 2-piece rotors for BRZ "with Brembo brakes":
https://www.knsbrakes.com/c/car-item...5_Brake+Rotors
Old 05-19-2020, 06:51 PM   #12
NaturallyAspirated
KNS Brakes is legit and I'd contact them to get more details.
I'm willing to bet the front rotors will be a direct fit, but as mentioned the rear hats will be different.
Old 05-19-2020, 09:20 PM   #13
KNS Brakes are good peoples.
- Andrew
Old 05-19-2020, 09:35 PM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
Aright I'ma give the a call or drop em a line tomorry...
Weight new rims with brembo. Alastor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-19-2019 11:52 AM
*SOLD* Shorai Light Weight Battery Kit FRS BRZ 86 Kinetic Custom Machine Lighter Race hirollaz Audio/Visual, Electronics, Infotainment, NAV 5 07-12-2017 05:56 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
Rotor Weight ender2664 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-14-2013 05:14 AM
Weight reduction in the front only KevinBRZ Scion FR-S / Toyota 86 GT86 General Forum 16 04-12-2013 12:25 AM
