Old 04-11-2013, 12:34 PM   #1
KevinBRZ
Weight reduction in the front only
Is there anything removable or replaceable in the front of the car only, to reduce weight? Other than a lightweight battery and no washer fluid which are basically obvious. So far I am thinking of a lightweight flywheel. Any other ideas? I'm looking to remove stuff more than replace.
KevinBRZ is offline   Reply With Quote
Old 04-11-2013, 12:37 PM   #2
ayau
Drives: Some rust bucket
The A/C if you can live with the heat. I believe some people have the bumper beams removed.
Old 04-11-2013, 12:41 PM   #3
vtmike
vtmike's Avatar
Drives: Scion FR-S
If you get something like the perrin inlet tube, it removes the sound generator which is maybe 2 pounds all together. Their CAI then removes the stock airbox which probably will have a net loss. Then they're light weight pulleys too. Not much weight but it's something.
Seems like many headers are around 10 pounds lighter and the front pipe is towards the front of the car. You could maybe save 15-20 pounds with those.
Sent from my Galaxy Nexus using Tapatalk 2
vtmike is offline   Reply With Quote
Old 04-11-2013, 12:41 PM   #4
dsmx17
4g63>rotards
Drives: 98'GSX 11'Tundra 10'Wrangler
a/c, evap (emissions) power steering and related components. thats about it without getting to crazy and removing windsheild wiper motor etc..
dsmx17 is offline   Reply With Quote
Old 04-11-2013, 12:43 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
Steering wheel?
Old 04-11-2013, 12:44 PM   #6
ayau
The thing with getting a lightweight battery is that the OEM battery is already mounted pretty much towards the center of the car. It's best to remove weight at either ends of the car, eg., the oem 25lbs muffler.
Old 04-11-2013, 12:46 PM   #7
whitejdm
Drives: BRZ prem.
Beatrush bumper beam (must weigh less than oem), lightweight battery, pulley's, flywheel, washer bottle delete, foglight delete (if you have limited), intake tube and sound generator.
Might save 30lbs or so, but definitely won't be enough to offset any weight loss on the rear (spare, seats, trunk junk, lighter exhaust) so you'll probably still see a net shift in the weight distribution to the front.
whitejdm is offline   Reply With Quote
Old 04-11-2013, 12:57 PM   #8
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Don't forget carbon fiber hoods, fenders, Lexan windshield, headers, on top of everything mentioned.
Scott
naikaidriver is offline   Reply With Quote
Old 04-11-2013, 01:02 PM   #9
Mild2Wild
Drives: Firestorm FR-S
Scott
It has already been established that carbon fiber hoods will most likely not save any weight. Visibility out of a Lexan windshield is also not the best...
Mild2Wild is offline   Reply With Quote
Old 04-11-2013, 01:13 PM   #10
naikaidriver
"Established" is not synonymous with "most likely".
And yes, you are correct but the topic was weight reduction and everything I mentioned is perfectly viable. It just depends on how far you're willing to go and how much you are willing to spend on the application.
Scott
Old 04-11-2013, 01:34 PM   #11
scottynoshotty
scottynoshotty's Avatar
Drives: Hot Lava 2013 Scion Frs
I think you would save more weight just taking the 1800 bucks for a dry carbon hood and flushing it down the toilet
scottynoshotty is offline   Reply With Quote
Old 04-11-2013, 01:37 PM   #12
camelflage
Drives: pinto power
bulimia...
camelflage is offline   Reply With Quote
Old 04-11-2013, 01:38 PM   #13
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Especially if you were going to pay in pennies.
-Justin
Justin.b is offline   Reply With Quote
Old 04-11-2013, 02:04 PM   #14
Mild2Wild
Scott
It has been "established" that, yes, unless spending thousands for a truly lighter hood, you should probably just put down the fork and "most likely" save more weight.
Official Component Weights & Weight Reduction Thread JRitt Tracking / Autocross / HPDE / Drifting 381 10-03-2024 08:02 AM
the weight reduction of FR - S? raiden8383 Scion FR-S / Toyota 86 GT86 General Forum 22 11-30-2012 06:10 PM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 05:09 PM
Weight..... icemang17 Tracking / Autocross / HPDE / Drifting 2 07-02-2012 06:24 PM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 10:43 PM
