Old 05-16-2020, 07:19 PM   #1
gt7877
Drives: turbo frs
Question p0030 issue A01I
Dear all
I have install aftermarket header for someone
2014 auto FRs. ...
ZA1JA01I
After few minutes engine light came
P0030
I have tune it stage 2 with Ecuflash
I disabled p0030
And all related o2 codes
But still keep coming even the code disabled from the map
What I can do
It take around 10-15 to show up
I return back to stock rom
When I turn switch on immediately cel show up same p0030
Crouse control stop
Sport mode disable
Gear changed hardly even I but it to manual mode
I have changed both O2 sensors but still same issue
Any idea??
Thnx
gt7877 is offline   Reply With Quote
Old 05-16-2020, 07:22 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Find the definitions for B01 and see if it comes on. If it only comes on when you flash the car, it's something with the map
Old 05-16-2020, 07:24 PM   #3
gt7877
Drives: turbo frs
Originally Posted by DarkPira7e View Post
Find the definitions for B01C and see if it comes on.
B01c for manual
I use Steve xml for all my flashing
One for auto
One for manual
Old 05-16-2020, 07:25 PM   #4
gt7877
Drives: turbo frs
It's show up after some time
But after flashing to stock show up immediately before even drive it
Old 05-16-2020, 07:41 PM   #5
DarkPira7e
DarkPira7e's Avatar
Are you sure the sensors are plugged into the right connectors? Have you tried switching them for fun?
Old 05-16-2020, 08:11 PM   #6
gt7877
Drives: turbo frs
R u sure
Old 05-16-2020, 08:22 PM   #7
DarkPira7e
DarkPira7e's Avatar
R u sure
Basic troubleshooting starts with physical first. Good luck then.
Old 05-16-2020, 09:35 PM   #8
tomm.brz
Drives: brz 2017 hksv2
either is a electric link fail on the connector, or you damaged the sensor while installing in header, they re pretty fragile
Old 05-16-2020, 09:44 PM   #9
gt7877
Drives: turbo frs
Also I have returned to stock header
With stock rom but still same issue
This happened after installing aftermarket header and off stage 2 tune
I return everything to stock but still same 😭
Old 05-16-2020, 10:52 PM   #10
gt7877
Drives: turbo frs
Originally Posted by solidsnake11 View Post
Did you check the Fuse??
Which one??
Location??
Photos if possible
Old 05-16-2020, 11:13 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Which one??
Location??
Photos if possible
Old 05-17-2020, 11:22 AM   #12
gt7877
Drives: turbo frs
Thnx to all
It was 15amb fuses
Old 05-17-2020, 02:49 PM   #13
solidsnake11
Drives: brz
Thnx to all
It was 15amb fuses
"It aint got no gas in it" "ummhuh"
I guess you guys are too young to get that.
Its from a movie called "sling blade"
solidsnake11 is offline   Reply With Quote
Automatic Transmission issue- dealer is not recognizing the issue, please help! Arrex Issues | Warranty | Recalls / TSB 36 06-03-2019 04:15 AM
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? darkbluemn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-05-2018 08:49 PM
P0134 and P0030->P0031 Howardwei Software Tuning 7 12-08-2013 02:39 PM
CODE P0134 and P0030 Howardwei Issues | Warranty | Recalls / TSB 2 11-06-2013 04:54 PM
Cel issue Z06tofrs Issues | Warranty | Recalls / TSB 2 08-27-2012 10:13 AM
