P0134 and P0030->P0031
Hi guys,
I have a Ecutek stage 1 tune by Perrin. The following are my mods: -catback 2month ago -Ecutek flash about 1 month ago or less. I have P0134 and P0030 popped up 3 days ago. and still there now. took it to the dealer. and they said the Secondary O2 is not sending or picking up signal. I was pretty honest to them since I didnt care about warranty. I was told it has to be the Tuning by Perrin. because it happens after I flash my car. but was assured by Perrin that its definitely not the map because I flash to stock and clear codes. still there. Perrin was nice to send me another map which is the same map since i told the the subaru tech think you guys might have messed up. Codes change from P0134 and P0030 to P0031 My question is, would the tuning ever screw up your O2 sensor? By screwing up, I mean not functioning or incompatible with the tune on a programming base. I think im just going to replace my O2 sensor at this point and see if that goes away. Thank you guys for reading!
#2 | |
I Love custom Turbo kits
Drives: Limited BRZ
Yes, a tune CAN foul your O2 sensors. No, I do not believe Perrin's tune was the reason it got damaged.
First, those codes point to your front, primary O2 sensor, not the secondary sensor.
It most likely is not the O2 sensor itself, but a wiring problem or loose wiring connector. I don't believe the tune would cause this. Check the wiring from the front o2 sensor -- trace the wires -- check all connections and make sure they are tight. Have someone with automotive electrical wiring experience and tools check voltage and resistance. Good luck in your troubleshooting! |
#4 | |
CODE/ O2 sensor
| The Following User Says Thank You to Howardwei For This Useful Post: | Circuit Motorsports (11-11-2013) |
#5 | |
#6 | |
You should not need any spacers/anti-foulers for your sensors! With the cat-back exhaust, you have not touched or affected either o2 sensor. It most likely will boil down to either wiring/electrical connector, or the o2 sensor just went bad for some unknown reason. I was suggesting you check the wiring and connectors before spending the money on a new o2 sensor. Again, best wishes in your troubleshooting. Let us know what you find. -- Bob |
Solution
Turn out my BRZ happen to have a malfunction A/F sensor. all i had was a catback and tune. the mechanic at subaru was trying to tell me it cant be the sensor. Thought he did a diagnose on my car but according to the local performance shop the diagnose took him like about an hour, not to mention the time you need to wait for the car to cool down before you can do anything. So basically the "Austin subaru"'s service department was trying to gip me. The sales person was great. he helped me out by reaching out to the service even though he has nothing at stake. The service saw my catback right after he plugged in the scanner and was like nope your warranty is voided. he thinks the oxygen sensor was bad because of my catback, and i was told he was one of their top notch mechanic even though the sensors were both in the header.
Never going back again.
Drives: 2013 FRS - 10 Series - Ignition
I was an Austin Subaru customer for 10 years. The next time you get a question there, ask for Billy. He's their head mechanic, actually won top Subaru mechanic in the US, and has been to Japan for further study. He's phenomenal. They like to hide him from customers due to him being overly "honest" with the customers, and not following the corporate line on what's best.
Sent from my iPad using Tapatalk |
| CODE P0134 and P0030 | Howardwei | Issues | Warranty | Recalls / TSB | 2 | 11-06-2013 04:54 PM |
