Old 05-16-2020, 12:26 AM   #1
jason_456788
Drives: 2017 brz
Extremely high LTFT trim. What's happening ?
It mostly happens during idle. I know normally it should be +/- 10% but this is way off. Anyone have any idea?
I have oft stage 2+ E85 tune . OFT catless uel header, Test pipe, N1 cat back, K&N drop in filter. Pretty much it. I would definitely appreciate any help I can get! Thank you! I have tried to reflash it, and it doesn't work. P0171 code showed up. As well as another code too but I forgot what code it was before I reflashed it.
Sent from my SM-N960U1 using Tapatalk
jason_456788 is offline   Reply With Quote
Old 05-16-2020, 12:27 AM   #2
jason_456788
Drives: 2017 brz
Update : as well as P2270 code.
Old 05-16-2020, 12:37 AM   #3
mrjj
Drives: GT86 2013
Exhaust leak near the header, maybe?
mrjj is offline   Reply With Quote
Old 05-16-2020, 12:38 AM   #4
jason_456788
Drives: 2017 brz
After the header or before?
Old 05-16-2020, 12:39 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Your car must be stupid loud.
Anyway, did this suddenly happen or did you just flash it for the first time and this is happening? Need a bit more backstory. High LTFT can be caused by a few things.
Where did you get this tune from? OFT does not supply an off the shelf e85 tune for 17+ cars as far as I was aware. The only way to get it is to have one modified from a different calid.
EDIT:
Here you go. Same issue as you are describing.
https://www.ft86club.com/forums/show...=121767&page=3
Fix:
https://www.ft86club.com/forums/show...1&postcount=36
Old 10-16-2020, 02:45 AM   #6
jason_456788
Drives: 2017 brz
Problem fixed it was all because of big ass crack from the beginning of the header all the way to the pipe. Also, it crackked before the o2 sensor.
High negative STFT and LTFT 86TOYO2k17 Issues | Warranty | Recalls / TSB 22 09-30-2025 03:10 PM
Diagnosing high positive LTFT Tectoniic Software Tuning 22 05-03-2022 02:24 AM
Help with e85 oft - ltft is very high Neos Software Tuning 4 05-15-2018 06:25 AM
LTFT high/low? Sel_brz17 Software Tuning 3 05-08-2018 06:48 PM
high ltft while running e85 with oft flat4_86 Software Tuning 4 01-22-2017 12:47 AM
