Drives: 2015 subaru Brz
high ltft while running e85 with oft
hey everyone, Ive had my OFT for about 5 months and after running the 91 stage 1 tune, which i enjoyed, I decided to try the stage 2 e85 tune and I love it! Ive been on it for about 5K miles. on my first tank my fuel trims looked good. ltft stayed at +3% and my stft stayed between -3-4%. and my second tank the stayed the same. but my ltft steadily has risen in the past few months. it goes up to +14%. ive been putting about 1.5 gallons of gas with every e85 fill up sinse I notice the rise of the Ltft and it brings it down to +3.12 and my Afr stays at 14.6.1 at idle. I haven't notice much knock, the most I've seen is -0.68 in low rpm 3d gear. I've done my oil changes every 3k miles and have cleaned my maf sensor in case My K&N filter was the issue but that didn't do anything. the only other modification my car has is a borla catback exhaust. ive read other threads, and some might say it could be an exhaust leak, but can my stock headers have a leak if they've never been touched? should I be worried? any helpful feedback is welcomed and thank you in advance.
I suppose it is is possible nothing is wrong with your car. Can you verify what E% your E85 is? +10% LTFT would indicate something like true 85%, which while rare is not unheard of.
Other than that, check O2 sensor is the last "easy" thing you can do.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
Drives: 2016 FR-S Raven
You could always run an ethanol content test on your next fill-up. Perhaps your fuel station has been stocking increasingly higher ethanol content e85.
Keep in mind that on your first tank you may have had 2 or so gallons of 91 remaining in the tank. Your next fill-up after that, the remaining fuel would have a high e content requiring 91 to be added to keep a similar mix. |
Drives: 2013 Scion Frs 6mt
Scale your MAF
Here are some datalogs I did on stage 2 e85 and stage1 91 octane
http://www.datazap.me/u/blades805/lo...0?log=0&data=1 |
| Running lean at high RPM | BigBrainedMonkey | Engine, Exhaust, Transmission | 5 | 08-30-2022 04:45 PM |
| Diagnosing high positive LTFT | Tectoniic | Software Tuning | 22 | 05-03-2022 02:24 AM |
| High Negative LTFT on N/A BRZ causing idling issues | paintdude258 | Software Tuning | 57 | 03-26-2017 08:14 AM |
| Crazy high LTFT, lean codes, e85... | nickw14 | Software Tuning | 18 | 06-23-2015 08:55 PM |
| high ltft at idle, my how to fix it(not fixed yet) | trdric | Software Tuning | 16 | 06-18-2015 10:27 PM |
