Old 05-07-2018, 10:24 PM   #1
Sel_brz17
Sel_brz17's Avatar
Drives: BRZ 2017
LTFT high/low?
I just tuned my brz using the oft! Its currently on stg1. MY Stft trim hovers arund -3%, which i think is fine.... myltft on the other hand hovers around -19% on idle and -15% while driving. I do believe its bc i got an injen intake on there. SHould i be worried? I realy dont wanna take off injen intake but will do so if needed. What can happen if I continue to run my car at these readings? Thank you!
Sel_brz17 is offline   Reply With Quote
Old 05-08-2018, 12:29 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Go to the software tuning forum and look at the guides and stickys. STFT will always fluctuate, a lot. LTFT is the average of the STFT and what you really need to be paying attention to, 5%+/- is okay for LTFT You likely need to datalog the car and make some maf scaling corrections. Your not going to kill your car running it currently like that but I would work on getting it corrected. That's way off, I'd double check the oring on the maf and make sure it is not nicked, damaged, or missing. I'd also hit it with some maf cleaner while you have it out.
OFT Guide
http://www.ft86club.com/forums/showthread.php?t=71157
Maf scaling info
http://www.ft86club.com/forums/showt...01#post1842501
Old 05-08-2018, 05:13 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
An intake will usually cause a positive LTFT, but usually not very high. I never scaled my MAF with my Injen intake and LTFT (on 93 stg 2 tune) was around +5 or so. -15 is awfully high negative, you have another problem going on there.
Go back to the stock tune and diagnose what the issue is from there. If you scale the MAF with a hardware issue, you may scale the LTFT back to near 0, but you are only hiding a problem.
What's your LTFT at idle, 2500 RPM and 3500 RPM?
Old 05-08-2018, 06:48 PM   #4
freerunner
freerunner's Avatar
Drives: GT86
If you choose to do a MAF scaling yourself, do it properly. Use direct injection injection only and calibrate your port injection against it.
Refer to:
freerunner is offline   Reply With Quote
High negative STFT and LTFT 86TOYO2k17 Issues | Warranty | Recalls / TSB 22 09-30-2025 03:10 PM
Diagnosing high positive LTFT Tectoniic Software Tuning 22 05-03-2022 02:24 AM
high ltft while running e85 with oft flat4_86 Software Tuning 4 01-22-2017 12:47 AM
Crazy high LTFT, lean codes, e85... nickw14 Software Tuning 18 06-23-2015 08:55 PM
high ltft at idle, my how to fix it(not fixed yet) trdric Software Tuning 16 06-18-2015 10:27 PM
