Drives: 2013 ARGENTO A/T
Play in SPC LCA bushing
I noticed this the other day while installing new coilovers. Is this normal? Sorry for the quality. The video is the rear LCA attached only to the hub.
https://imgur.com/a/EgUHiBq |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
Seems like a tremendous amount of movement. Is it cracked and splitting?
Work Hard. Play Hard.
2016 Oceanic |
Terrible video! Try putting the light behind you next time.
I am guessing that is a end bearing Those will wear out and need replaced. Rotational movement on that is not an issue you need to check it for play in and out. |
That's the spherical joint in the wheel hub, not the spc lca, it's supposed to have multiple degrees of freedom. As long as you don't have unusual noises back there it's probably fine.
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Can't see video because imgur is being a shit, but I don't think I could see the video even if imgur was allowing me, just from the thumbnail I can tell that I wouldn't be able to see a thing.
The rear lca has the wheel end joint pressed into the knuckle, I've seen a few of those go bad on foresters, it should rotate freely, but axial and lateral play are a big no-no. Even if there is no noise, play in that spherical joint means bad alignment. https://www.whiteline.com.au/product...63412&sq=24130 |
#6 | |
Movement in an undesired axis would be wear, which means it's loose, which means it would make noise when loaded and unloaded.
| Rear Lower Control Arm Solid Bushing vs Rubber Bushing NVH | Infinity | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 12-28-2023 09:12 AM |
| WTB: Mtec Springs/Trans Mount Bushing/Rear Shift Bushing | 86dev | Want-To-Buy Requests | 2 | 03-14-2018 03:07 PM |
| Whiteline bushing inserts vs. full bushing replacements | mhiscott | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 12-15-2015 11:45 AM |
| Whiteline transmission bushing and Perrin shifter bushing review. | Superhatch | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 12-09-2012 08:40 PM |
| How its going to play out | 47corolla | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 04-25-2012 06:05 PM |
