Old 11-10-2019, 07:13 PM   #1
Infinity
Drives: 2016 Scion FR-S
Rear Lower Control Arm Solid Bushing vs Rubber Bushing NVH
The SPC rear lower control arms have a solid bushing they call the xAxis Sealed Flex Joint. SPC claims it performs like a pillow joint.
Can anyone with these control arms post if they have any increase in NVH over stock? Do they squeak? I rode in a friends car with several solid bushing suspension pieces and it was kind of noisy.
The Whiteline rear lower control arms come with synthetic elastomer bushings. These will most likely not make any noises. They end up being about $50 more expensive than I can get the SPCs for, though.
The SPCs also come with a toe kit. Is this necessary? No other RLCAs seem to come with one.
I know the SPC would not be legal for STX and the Whiteline would. Autocross is not really my primary concern, I am more worried about the NVH. If that ever became an issue I know there is a rubber bushing for the SPC made by DIFtech.
Infinity is offline   Reply With Quote
Old 11-10-2019, 07:17 PM   #2
strat61caster
strat61caster's Avatar
The diftech bushing is delrin, a hard solid plastic, it would be the noisiest of the three options. Sounds like a no brainer for you to spend the extra $50 on the Whiteline.
ineedyourdiddly
Old 11-10-2019, 07:26 PM   #3
Infinity
If the toe kit included with the SPCs is not needed, the Whitelines are probably the way to go.
Old 11-10-2019, 10:35 PM   #4
strat61caster
They are not, factory toe adjustment is adequate for all sane levels of camber and lowering.
ineedyourdiddly
Infinity (11-11-2019)
Old 11-10-2019, 10:54 PM   #5
86MLR
86MLR's Avatar
I got these, they work fine
https://www.sparesbox.com.au/part/su...subaru-trc0015
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
Old 11-13-2019, 10:40 AM   #6
Infinity
I just noticed that according to CounterSpace Garage, the SPC RLCA is STX legal.
https://www.counterspacegarage.com/s...0-brz-frs-gt86
So the only question now is if the SPC units have any noticeable increase in NVH over stock?
Old 11-13-2019, 10:40 AM   #7
Infinity
Old 11-13-2019, 12:24 PM   #8
strat61caster
@Infinity they're wrong, they know it, they just never updated the website.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
DocWalt (01-31-2022), wparsons (11-14-2019)
Old 11-13-2019, 04:44 PM   #9
G-awesome
Drives: 2015 Firestorm Scion FRS
This is based on my experience but don't all polyurethane bushings squeak to an extent since it's usually thicker and fills up all the gaps in the subframe mount so it rubs and squeaks as it constantly moves around? Especially now that the weather is colder?
I have Blox Racing LCAs and the rear right side squeaks like mad and it's starting to drive me crazy now after half a year of use for daily driving. Maybe it's because it's dirt cheap LCAs and the polyurethane bushings aren't as high quality?
Once I swap with winter tires, I'll inspect the suspension and see what's up. Or I'll just throw more grease on and call it a day because I'm just too damn lazy to deal with my car sometimes.
G-awesome is offline   Reply With Quote
Old 11-14-2019, 09:42 AM   #10
wparsons
wparsons's Avatar
Polyurethane bushings need grease to be quiet, they should've included it with the arms.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
G-awesome (11-14-2019)
Old 11-14-2019, 06:44 PM   #11
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
Can confirm. My Perrin endlinks squeaked a lot until it was greased up.
kevaughan is offline   Reply With Quote
The Following 2 Users Say Thank You to kevaughan For This Useful Post:
G-awesome (11-19-2019), wparsons (11-19-2019)
Old 11-14-2019, 06:55 PM   #12
norcalpb
norcalpb's Avatar
OEM uses the same cross axis design as SPC, so I doubt there’d be a noticeable NVH change.
And yes they are not STX Auto-x legal.
I have the white lines but kinda wish I got the SPCs. Pillowball/crossaxis will always handle better than polyurethane.
The Following User Says Thank You to norcalpb For This Useful Post:
Infinity (11-14-2019)
Old 12-28-2023, 09:12 AM   #13
J95
J95's Avatar
Reviving this thread to ask If you think theres any difference in durability/reliability for the SPC "pillowball" bushing vs Whiteline PU bushing?
I would not mind NVH but I will try to buy the most "reliable" one. Otherwise I will just get the cheapest from the two
J95 is offline   Reply With Quote
Lower control Arm Bushing Squeaking Dylon Issues | Warranty | Recalls / TSB 0 10-15-2019 11:19 AM
WTB: Mtec Springs/Trans Mount Bushing/Rear Shift Bushing 86dev Want-To-Buy Requests 2 03-14-2018 03:07 PM
Front Control Arm Bushings Flawed - Rear Bushing Acree Issues | Warranty | Recalls / TSB 9 10-04-2013 04:19 PM
TIC Solid Steering Rack Bushing's Track Review track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-17-2013 01:24 PM
WORKS Rear Upper Control Arm Bushing - Inner Camber Correction 86_ZN6 Brakes, Suspension, Chassis 0 02-06-2013 12:20 AM
