| Engine Swaps Discussion of engine swaps. |
Drives: GT86
help need a 24K plug and play solution (GT86 SWAP)
hi every one I'm thinking to swap a K24 (lite weight cheap excellent HP) but the ECU solution motc 150 is too expensive any suggestions or other solutions????
Drives: Q5 + BRZ + M796
86 ecu
Drives: GT86
Drives: 2013 FR-S Ultramarine
That doesn't exist.
has a funny hat
Drives: 2014 BRZ Limited
Hack and tune the factory ECM to run the Honda motor, there is a thread detailing it being done. Or, spend the money on the Motec. Those are likely your only options if you insist on maintaining factory equipment that relies on the CAN bus like the dash, abs, traction control, etc.
Engine swaps are expensive. Cheap swaps doubly so. Last edited by pope; 05-14-2020 at 03:33 PM. Reason: spellcheck |
| The Following User Says Thank You to pope For This Useful Post: | Tcoat (05-15-2020) |
Drives: JRSC BRZ SOLD
Nothing cheap about a Kswap other than the motor. The stand alone is the best solution.
Drives: GT86
I contact AGT engineering this is what they said
Yes no worries. The wire in translator can be used with just about any engine. It just needs a Tacho rpm input, a temperature sender input and then there are a few wires that can be used to get the Check Engine light working and Air-Con request if AC is required. This will also get rid of the ABS and traction control warning lights, ABS will still work but not traction control. It will also get the electric power steering working. Regards, Andrew I'm not sure if will go for it |
#8 | |
Drives: GT86
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | solidsnake11 (05-14-2020) |
#10 | ||
Drives: GT86
OMG Quote:
I don't think that's I will do that I will wait for a clean solution (plug and play) I'm sure that I will blowup the engine I don't want to deal with this thanks |
#11 | |
Take what options there are or forget the whole thing.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#12 |
Remember me?
Drives: BRZ Series.Blue
Wiring Specialties will have a "full PnP setup with CANbus no later than early 2021" Details to come after black friday.
#13 | |
Drives: 2017 Toyota 86
| The Following User Says Thank You to anticubus For This Useful Post: | Tcoat (10-21-2020) |
#14 | |
Drives: 2013 FRS
I reached out wondering what ecu they were going to use, and it seems like a haltech 1500 is a likely candidate, full canbus. |
| The Following User Says Thank You to steved For This Useful Post: | wparsons (10-30-2020) |
| Are GT86 Headlights Plug and Play with FRS? | tbwoodlee | Cosmetic Modification (Interior/Exterior/Lighting) | 93 | 03-01-2018 07:48 PM |
| Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 11:10 AM |
| AU GT86 Rear view camera Plug-n-play on Canadian (Pioneer) navigation system ? | Simon99 | Electronics | Audio | NAV | Infotainment | 26 | 04-24-2014 04:38 PM |
| FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 10 | 08-30-2013 10:53 AM |
| HID Plug 'n Play Kit | JW89225 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 24 | 07-31-2012 12:17 AM |
