Old 05-13-2020, 06:00 PM   #1
najaray
Drives: GT86
help need a 24K plug and play solution (GT86 SWAP)
hi every one I'm thinking to swap a K24 (lite weight cheap excellent HP) but the ECU solution motc 150 is too expensive any suggestions or other solutions????
najaray is offline   Reply With Quote
Old 05-13-2020, 10:00 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
86 ecu
Old 05-14-2020, 08:20 AM   #3
najaray
Drives: GT86
86 ecu
I mean plug and play solution, thanks for the replay.
Old 05-14-2020, 09:54 AM   #4
Chickeneatman
Drives: 2013 FR-S Ultramarine
That doesn't exist.
Chickeneatman is offline   Reply With Quote
Old 05-14-2020, 10:23 AM   #5
pope
has a funny hat
Drives: 2014 BRZ Limited
Hack and tune the factory ECM to run the Honda motor, there is a thread detailing it being done. Or, spend the money on the Motec. Those are likely your only options if you insist on maintaining factory equipment that relies on the CAN bus like the dash, abs, traction control, etc.
Engine swaps are expensive. Cheap swaps doubly so.
pope is offline   Reply With Quote
The Following User Says Thank You to pope For This Useful Post:
Tcoat (05-15-2020)
Old 05-14-2020, 01:31 PM   #6
PulsarBeeerz
Drives: JRSC BRZ SOLD
Nothing cheap about a Kswap other than the motor. The stand alone is the best solution.
PulsarBeeerz is offline   Reply With Quote
Old 05-14-2020, 03:28 PM   #7
najaray
Drives: GT86
I contact AGT engineering this is what they said
Yes no worries. The wire in translator can be used with just about any engine. It just needs a Tacho rpm input, a temperature sender input and then there are a few wires that can be used to get the Check Engine light working and Air-Con request if AC is required.
This will also get rid of the ABS and traction control warning lights, ABS will still work but not traction control. It will also get the electric power steering working.
Regards, Andrew
I'm not sure if will go for it
Old 05-14-2020, 03:48 PM   #8
najaray
Drives: GT86
Can you send the thread detailing the hack factory ECU
Old 05-14-2020, 04:03 PM   #9
Irace86.2.0
It was three threads below this one.
https://www.ft86club.com/forums/showthread.php?t=138819
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
solidsnake11 (05-14-2020)
Old 05-14-2020, 05:09 PM   #10
najaray
Drives: GT86
OMG
Originally Posted by solidsnake11 View Post
More progress; factory port ratio.
It doesn't have any water in it so I can't run it long.
Sounds like a two stroke.
A lot of extra wires.
Attachment 185022Attachment 185023Attachment 185024
I don't think that's I will do that I will wait for a clean solution (plug and play) I'm sure that I will blowup the engine I don't want to deal with this thanks
Old 05-15-2020, 09:00 AM   #11
OMG
You could wait a long long time then. There are not going to be many new things developed for this platform this far into it's life.
Take what options there are or forget the whole thing.
alphasaur (10-23-2020), anticubus (10-21-2020), solidsnake11 (05-15-2020), Wally86 (10-22-2020)
Old 10-21-2020, 12:13 PM   #12
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Wiring Specialties will have a "full PnP setup with CANbus no later than early 2021" Details to come after black friday.
glorydays is offline   Reply With Quote
Old 10-21-2020, 06:51 PM   #13
anticubus
Drives: 2017 Toyota 86
Not only is this how it'll be for a long time, but IMO the cleanest solution is to use the stock ECU. Seeing @solidsnake11 do it put a smile on my face because I can now say we've reached the era where you don't need to perform brain surgery to go along with your heart surgery (just some intense post-op therapy) without a paid engineering team.
anticubus is offline   Reply With Quote
The Following User Says Thank You to anticubus For This Useful Post:
Tcoat (10-21-2020)
Old 10-22-2020, 01:13 AM   #14
steved
Drives: 2013 FRS
A bit pessimistic.. kmiata/kpower is working on a swap kit.. https://www.google.com/url?sa=t&sour...rKn33FzA5YDpAU
I reached out wondering what ecu they were going to use, and it seems like a haltech 1500 is a likely candidate, full canbus.
steved is offline   Reply With Quote
The Following User Says Thank You to steved For This Useful Post:
wparsons (10-30-2020)
Are GT86 Headlights Plug and Play with FRS? tbwoodlee Cosmetic Modification (Interior/Exterior/Lighting) 93 03-01-2018 07:48 PM
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
AU GT86 Rear view camera Plug-n-play on Canadian (Pioneer) navigation system ? Simon99 Electronics | Audio | NAV | Infotainment 26 04-24-2014 04:38 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
