Old 12-15-2012, 11:02 AM   #1
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
Are GT86 Headlights Plug and Play with FRS?
EDIT
I just wanted to put in a quick edit to let newer members of the thread know the answer the question I asked in December. No they are not directly compatible, but it is a very easy fix to be honest.
In this thread Moto-P has provided an excellent source of information on how to repin them to make them functional. So, if you are thinking about getting the lights, but are worried you cannot install them, have no fear. It is actually one of the easier DIY's I have done to the car. I made a quick DIY that you can read here:
Installing GT86 Headlamps on your FR-S
Original Post below
Hey guys, I am about to order the LHD w/ Eurospec leveling GT86 headlights. For those who have done this, are they plug and play or am going to have to do additional work once I receive the lights? I have tried searching but I am not having any luck.
I guess if no one knows I will have to be the test subject. Thanks guys.
tbwoodlee is offline   Reply With Quote
Old 12-15-2012, 01:27 PM   #2
Frostyman
Drives: 2013 Raven FRS
Go to speedhunters. I'm almost 100% certain there was a step by step article they did on using EDM lights in an FRS
Frostyman is offline   Reply With Quote
Old 12-15-2012, 01:32 PM   #3
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
Awesome, thanks man, I will check it out. I appreciate the help.
Old 12-15-2012, 01:38 PM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
no. wiring harness and connectors are different
86_ZN6 is offline   Reply With Quote
Old 12-17-2012, 02:13 PM   #5
paperboy42190
Drives: 2007 Acura TL Type-S
yea its a bit different, might need work
paperboy42190 is offline   Reply With Quote
Old 12-17-2012, 03:07 PM   #6
WWEVOX
Drives: White Lancer Evolution X
I've done it and it's not too hard.
The connectors are different, jdm/eudm is an 8 pin connector (only six live pins), and the usdm is a 6 pin connector (only 4 live pins). So I de-pinned each and put all 6 pins from the jdm lamp into the 6 pin usdm connector. (I don't know the wiring off the top of my head but maybe I'll do a DIY write up.)
Reference: the wiring harness has 6 live pins but the usdm lamp is only using 4 (since High beams and DRLs are on the same line). The two unused pins are live when parking lights or headlights are turned on, so I pinned up the LEDs to those. And now I have full LED DRL and HID low/high functionality.
If you feel okay to take off the bumper and re-pin, it's not too bad.
WWEVOX is offline   Reply With Quote
Old 12-17-2012, 03:22 PM   #7
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
http://www.garagefrs.com/jdm-headlight-conversion/
you are welcome
plan to do the same later next year
GT86drifter is offline   Reply With Quote
Old 12-17-2012, 03:35 PM   #8
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
I expected a wiring change, but I was being hopeful there would not be one, however this seems really easy. Thank you very much guys.
Old 12-17-2012, 07:01 PM   #9
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
How much are these lights going for these days?
tripjammer is offline   Reply With Quote
Old 12-17-2012, 09:54 PM   #10
Kurenai
Drives: 2013 Scion FR-S Hot Lava 6AT
Thats.. interesting.. are there no 'brights' with the EUDM/JDM HIDs?
Kurenai is offline   Reply With Quote
Old 12-18-2012, 02:29 AM   #11
WWEVOX
So I looked at FRSgarage and how they did it but I prefer it my way. So the FRS High beams and DRLs are on the same wire. So what they did is plug that wire into the JDM LED DRLs and just left the high beams out. So they only get low and DRL, no high beams.
Instead of doing that, I removed the DRL resistor so that the DRL/high beam wire only works for the high beams (resistor is under the right lamp when you take off the bumper). Low beam wires go to the low beams. And the unused wires turn on the LEDs whenever the parking, low, or high beam lights are on. You lose the DRLs but I just run with the parking lights on.
You can see them here:
http://www.ft86club.com/forums/showthread.php?t=20956
Old 12-18-2012, 06:49 AM   #12
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
There has not been much of a change in price to my knowledge, still about 2k.
Hmm... I like the sound of that. I would prefer that my LEDs be on all the time.
So I am about to order these, clearly I need the LHD euro spec, but do I need the leveling sensor? I am assuming that I do.
Thanks again for all the help and input fellas.
Old 12-18-2012, 12:31 PM   #13
WWEVOX
LHD eauro spec is the best way to go. You would likely get the high light cutoff on the correct side. However, I understand that if you order right from the factory, you will get the lamp unadjusted for either side, meaning you wouldn't blind people in either direction but you also don't benefit from a little extra lighting. My lamps are like this. Since I'm not being a blinding jerk to anyone, I don't mind not having the extra lumination off to the side.
The leveling sensor isn't necessary. The default position is the "0" height so it's where you would have your lights set most of the time. (but in case you want leveling, you need the sensor and leveling ecu).
Old 12-18-2012, 07:56 PM   #14
tripjammer
tripjammer's Avatar
I don't understand why these are still $2k! Hopefully the price will drop next year or the 2014 model FR-S will have hids...
gt86, gt86 headlights, headlights, lhd
Plug N Play Super Bright LED Kits @ JWM- FREE SHIPPING! JWMotoring Interior Parts (Incl. Lighting) 166 03-23-2014 08:08 PM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
Xenon HID Conversion PLUG & PLAY jarviz Cosmetic Modification (Interior/Exterior/Lighting) 5 08-01-2012 05:34 PM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-20-2012 11:10 PM
