Old 05-13-2020, 07:48 AM   #1
Ahmad Attia
Noise in the Engine
Hello Guys,
I need your help in this issue
I've changed the spark plugs and cleaned the 8 injectors by specialist,
After that there was a loud knocking noise or something blowed up in the engine on rpm 2-3 and there is almost no power.
Ahmad Attia is offline   Reply With Quote
Old 05-13-2020, 07:52 AM   #2
Gloonge
Drives: 2013 frs raven
Was your engine part of the valve spring recall? What year is it?
Gloonge is offline   Reply With Quote
Old 05-13-2020, 08:53 AM   #3
Ahmad Attia
Nope, 2013
There was a valve spring recall in america?
Old 05-13-2020, 08:55 AM   #4
Gloonge
Yea the 13' scions had it. Don't believe the Subaru or Toyotas did.
Not really sure what else to give. What happened leading up to this issue?
Old 05-13-2020, 09:01 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC it's world-wide recall for 2013 to early 2014. Try checking eg. here. Or at dealership.
Old 05-13-2020, 09:02 AM   #6
Ahmad Attia
It happened straight away after replacing the spark plugs and cleaning the 8 fuel injectors.
Old 05-13-2020, 09:03 AM   #7
Gloonge
Sounds like your injector specialist messed up then. They need to fix it. Does it smell like fuel under the hood?
Old 05-13-2020, 10:51 AM   #8
They all had it. They are all the same bloody car.
DarkPira7e (05-13-2020), Ultramaroon (05-13-2020)
Old 05-13-2020, 10:53 AM   #9
Make sure they put all the plug wires/coil packs back in the right place
Old 05-13-2020, 10:55 AM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Make sure you reconnected your coilpacks and are grounding out the DI harness with the screws
DarkPira7e is online now   Reply With Quote
The Following User Says Thank You to DarkPira7e For This Useful Post:
Tcoat (05-13-2020)
Old 05-13-2020, 11:01 AM   #11
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
How straight away after did it happen? Like right on start-up or first drive? Did something fall into the intake through injector hole? Maybe there was that one screw you couldn't find?
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following User Says Thank You to ActionMaxon For This Useful Post:
soundman98 (05-13-2020)
Old 05-13-2020, 01:21 PM   #12
Ahmad Attia
No fuel smell at all
Old 05-13-2020, 01:23 PM   #13
Ahmad Attia
At happened after 2 days around 80km
Old 05-13-2020, 08:58 PM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
wait.... 8 injectors? Loud popping sound, maybe?
Engine noise Antisocialspeed Engine, Exhaust, Transmission 4 09-20-2019 10:06 PM
Engine/Transmission noise N1rve Issues | Warranty | Recalls / TSB 48 05-06-2018 10:17 PM
Really odd engine noise Deadspool Engine, Exhaust, Transmission 52 03-10-2014 12:43 PM
Another Engine noise Vegas86 Issues | Warranty | Recalls / TSB 4 10-09-2013 12:30 PM
Engine noise somejace BRZ First-Gen (2012+) — General Topics 4 09-19-2013 06:39 AM
