Old 05-10-2020, 05:02 AM   #1
grumpysnapper
grumpysnapper's Avatar
Lithium Battery mounting and isolator
I hate the messy battery terminal wiring on our cars so when my Braille 904 battery finally failed with age, I decided to change to lithium, and try to clean up a bit.
Decided on a Lithiumax at about half the weight of the 904 at 2.5kg, and with 48 AH... for about the same replacement cost.
Comes with a very nice optional alloy mount and an ABS baseplate.
This was my solution. Still 1kg lighter in total than the Braille, so very happy.
(and please excuse the temporary velcro wrapping on the right of picture)
grumpysnapper is offline   Reply With Quote
Old 05-10-2020, 06:17 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Very neat job. And you even managed to keep the OEM red cover....
BTW, why is the 'green' indicator on the isolator saying "No"?
Old 05-10-2020, 06:20 AM   #3
mrjj
Drives: GT86 2013
LOL! You need to stand on your head or rotate your phone.
mrjj is offline   Reply With Quote
Old 05-10-2020, 07:04 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Interesting. Can you post detailed nfo, of what model is this battery, what was included, what was needed to custom make/customize in car and such (some DIY guide form)?
Old 05-10-2020, 07:41 AM   #5
grumpysnapper
For sure, I will just need a little time
Old 05-10-2020, 11:35 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
so what's the distribution block for just in front of the battery?
Old 05-10-2020, 11:39 AM   #7
soundman98
soundman98's Avatar
an old coworker once told me the story. he apprenticed to be an electrician under a very difficult retired military guy.
he once mounted a switch upside down, and at least in america, many of the switched have 'off' and 'on' embossed in them. so when it's upside down, it says 'no' like that.
his boss came to him screaming "you're doing it wrong, so wrong even the switch is telling you NO!"
Old 05-10-2020, 11:33 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'll guess it's part of the charge balancing circuitry. Charge rate of each cell must be controlled individually.
Old 05-11-2020, 12:17 AM   #9
grumpysnapper
Yep, it’s marine grade distribution block for all those annoying “extras” ... spot lights, stereo, oil cooler fans etc. Also serves as the charge input for the trickle charger and sensor.
Old 05-11-2020, 12:21 AM   #10
grumpysnapper
Nah, it’s a simple marine grade distribution block (neg and pos) 🙂
Old 05-11-2020, 12:59 AM   #11
Ultramaroon
not playing cards
Well, ok. I guess it could be that too.
Old 05-11-2020, 01:19 AM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I probably have 200 of those blocks at work. We use them for various assemblies. I used one in my Toyota when I relocated the battery and to wire up accessories.
FS: Shorai LFX36L3-BS12 Lithium Battery, 4.8lbs Dan37BRZ Engine, Exhaust, Bolt-Ons 2 03-01-2018 12:39 AM
Lithium Ion Battery Replacement Benzin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 06:05 PM
Pulse P3 Lithium Ion battery in Evasive's FR-S Evasive Motorsports Tracking / Autocross / HPDE / Drifting 15 07-11-2013 05:03 PM
Lithium Ion Battery Flat Black VW Scion FR-S / Toyota 86 GT86 General Forum 1 11-09-2012 02:23 PM
Lithium battery questions TuxedoCartman Electronics | Audio | NAV | Infotainment 2 11-07-2012 04:51 PM
