Old 05-08-2020, 04:53 PM   #1
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Leaky Quick Jack couplers
Here's some information and pics regarding the quick disconnect couplers on the Quick Jack BL-5000SLX Car Lift (I would assume all models of Quick Jack use the same coupler)
After 2.5 years of occasional use, I had a set of couplings fail. Half of a torn O-ring from inside the male coupler got stuck inside the female coupler so both were leaking.
I contacted Bendpak (https://www.bendpak.com/support/) and since my unit was out of warranty, I was given the option to purchase a new set for $79.99 plus shipping....I said no thanks. At the time I thought I needed 2 sets so that wasn't happening.
So there's option 1, buy a new set from Bendpak and move on with your life.
I didn't like option 1 so I went on a hunt for a suitable replacement online. Turns out, finding the correct set is not as easy as one would think. Here is what I found. The couplers are ISO 16028, 1/4" NPT Thread, 1/4" Body, flat face couplers and can be purchased on Amazon from Summit Hydraulics for $34.95. I like option 2. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
So while I'm waiting for the parts to come in, of course I had to go and "dig" a little deeper. Turns out, I was able to remove the torn O-ring from both halves and with a little finesse, replace the O-ring with a common size from the local home improvement plumbing department. It happens to be a #7 O-ring, 1/2" O.D. x 3/8" I.D x 1/16".
I found that I had to remove the white plastic "retainer" first, work the new O-ring into place, then re-insert the white plastic retainer on top of the new O-ring. It's kind of delicate work so if you have big 'ol sausage fingers, you might be better off with option 2.
BirdTRD is offline   Reply With Quote
Old 05-10-2020, 06:46 AM   #2
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
good work - bit of DIY saves the day and your wallet!
sneaky_pete is offline   Reply With Quote
Old 05-10-2020, 10:25 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Fantastic! I have one that had damaged threads out of the box. I cuss at it every time I clean up the little red puddle. :/
I love your jig, BTW. Stealing that too.
Old 07-17-2021, 02:26 PM   #4
atrank
Drives: 08 335xi
Thanks!!!!
This also applies to Ranger QuickJack lifts. Thanks so much for posting this! It just saved me a boatload of time trying to measure a ripped o-ring, and saved me $45 to $80!!!!! Why buy a pair of whole fittings when the problem is just an 18 cent o-ring!!!!!
atrank is offline   Reply With Quote
Old 07-19-2021, 02:07 PM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
nice. i also have quickjack but dont have problem yet. this would be handy in future. great job
Changing oils by myself, are these a recommended jack+jack stand? btan219 BRZ First-Gen (2012+) — General Topics 67 10-23-2021 03:54 PM
Leaky Exhaust Steveiam Engine, Exhaust, Transmission 3 09-08-2019 04:45 PM
WTB: Low profile floor jack and jack stands! lupindub Want-To-Buy Requests 2 11-26-2015 11:03 PM
Any TSB recalls for leaky cam plate / oil leaks? radroach Issues | Warranty | Recalls / TSB 0 12-05-2014 05:18 PM
Possible Leaky Taillight Fix Sco2355 Issues | Warranty | Recalls / TSB 6 02-18-2013 02:26 PM
