Old 09-07-2019, 10:14 PM   #1
Steveiam
Drives: 86
Leaky Exhaust
Hey guys I got the MXP SP catback and I noticed some water dripping on the connection. So I tested to see if there's any leak with soap water and both of the connections started bubbling. The donut gasket flange is fine but the other 2 connection isn't. I took it to some muffler shop and they wanted to weld it together but I told them no since I want them in separate pieces if I were take it off.
I feel like I've tightened it enough but could I have overtightened it? Any suggestions or solutions appreciated.
Steveiam is offline   Reply With Quote
Old 09-07-2019, 10:32 PM   #2
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Undo the exhaust and add Permatex Ultra Copper then reassemble.
A lot of people I know with slip on exhausts use this.
Or just leave it alone. It's tiny in terms of leaks but I can understand wanting that to be perfect.
Joon525 is offline   Reply With Quote
Old 09-08-2019, 03:27 PM   #3
Steveiam
Drives: 86
Is this considered a minor leak? I'm just wondering if the leak of this size affects the cabin noise.
[ame]https://www.youtube.com/watch?v=d1m38h43AlU[/ame]
Old 09-08-2019, 04:45 PM   #4
ls1ac
ls1ac's Avatar
Get a band clamp.
Leaky Camplate, Timing cover, Dealership, Oh My.. MuseChaser Engine, Exhaust, Transmission 6 10-02-2018 02:30 PM
Leaky axle/diff seal? slyphen Issues | Warranty | Recalls / TSB 28 03-01-2018 01:30 PM
Leaky weld on Tomei UEL header BirdTRD Engine, Exhaust, Transmission 17 06-20-2017 11:31 AM
Any TSB recalls for leaky cam plate / oil leaks? radroach Issues | Warranty | Recalls / TSB 0 12-05-2014 05:18 PM
Possible Leaky Taillight Fix Sco2355 Issues | Warranty | Recalls / TSB 6 02-18-2013 02:26 PM
