Old 04-18-2020, 05:12 PM   #1
Windycitystig
Drives:
Help installing sway bar bushings
I bought an 18 mm Whiteline rear sway bar. I need to install the new bushings on the bar. I can’t get the one-piece bushings to open enough to place them over the bar. Does anyone have any tips?
Windycitystig is offline   Reply With Quote
Old 04-18-2020, 10:11 PM   #2
motosteveo
motosteveo's Avatar
Drives: 2013 WRB 6MT
I had the same problem with my exhaust hangers when I put them on. A little WD40 did the trick
motosteveo is offline   Reply With Quote
The Following User Says Thank You to motosteveo For This Useful Post:
Windycitystig (04-19-2020)
Old 04-21-2020, 12:00 PM   #3
norcalpb
norcalpb's Avatar
Oh man this is the worst part of any sway bar install lol.
What I do is is lube the inside of the bushing channel, and then take a really wide flat head screw driver and keep prying the bushing opening to give it a bit more play. Once it frees up I’ll put the screwdriver in the corner of the bushing (so only part of the bushing opening is pried open), and then take that narrow/lubricated opening and force it onto the bar.
The Following User Says Thank You to norcalpb For This Useful Post:
strat61caster (04-21-2020)
Old 04-23-2020, 10:35 AM   #4
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
getting anything into a tight space just requires a bit of lube...
you could try putting them in near boiling water for a couple of minutes to soften them up a bit.
sneaky_pete is offline   Reply With Quote
Old 04-23-2020, 01:12 PM   #5
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Yeah. I had the same issue. I eventually manhandled it on. A lot of cursing.
Ernest72 is offline   Reply With Quote
Trd sway bar bushings? islandguy69 Issues | Warranty | Recalls / TSB 3 09-30-2017 01:18 PM
TRD Sway Bushings Sweet Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-26-2017 06:34 AM
WTB Rear TRD sway bar and bushings. Boostmaniac Want-To-Buy Requests 0 09-05-2016 09:10 PM
Will installing sub frame and tranny mount bushings cause premature wear? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-16-2013 03:56 PM
Urethane Sway Bar Bushings? phm14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-16-2013 10:32 PM
