Bent OEM Rear Endlink
![]() Bent my passenger rear OEM endlink. Wasn't a huge deal, replaced them with Racer X adjustables, just curious if anyone else has run into this issue. Suspension setup below: - RCE T2's (400/400 springs, lowered ~1") - OEM F/R swaybars - OEM endlinks Car has probably done 8-10 trackdays with the above setup, either on 235 RS3's or 225 BFG Rivals.
2022 BRZ Build 2013 FR-S Build |
Drives: Crapcan
I bent a stock front, think it was the left side. I can see that being more likely than the rear just by virtue of being longer. Kind of wild to see a rear bent like that. Makes you realize how much deflection is in the stock bushings.
Yeah I always figured I'd bend a front not a rear given how short the rears are. I still can't figure out if this was from normal track use or from hitting something. Hopefully these Racer X ones are stronger.
Impressive. I’m replacing my endlinks this week but only because the boots are torn. I can’t believe your link bent before the fragile rubber boot tore.
Drives: FR-S Whiteout
Did you catch some good air off some curbing with your car before discovering this? And the rest of the assembly is not bent or warped or broken at all?
Intent > Content
cowardice is the mother of cruelty. |
#6 | |
Yeah nothing else is bent or broken, just the endlink.
If the Racer X endlinks don’t work out, give Moog a shot. They are just like oem but the rod is much beefier.
| The Following 3 Users Say Thank You to norcalpb For This Useful Post: |
Good that the bar and the mounts survived. Now you have a perfect excuse to get something adjustable. Tax-write-off-able repair expense. haha
Intent > Content
| The Following User Says Thank You to solidONE For This Useful Post: | DarkSunrise (03-23-2020) |
Yeah that looks pretty solid. Thanks for the suggestion!
#10 |
Drives: 2016 Scion FRS Release Series 2#439
I used MOOG up front when I installed my Koni/TRD combo. Note that MOOG have grease fittings and also allow use of a spanner to hold the bolt for tightening. Others only allow use of the 6mm Allen to hold the bolt. Works fine for installion. Good luck years later when trying to remove.
#11 | |
Drives: Crapcan
I had Perrin non adjustable up front and they hit the inside of the wheel well really bad.
#12 | |
#13 |
Not related entirely, but Perrin front sway bar has fitment problems. FYI I told them about it they just sent me the same thing with the same problem.. too much play in the collars left to right.
Intent > Content
#14 | |
Drives: Crapcan
My issue is the top of the link where it connects to the strut though. Went to the whiteline end link which is much narrower to solve my issue.
| FS:(NJ) 13 BRZ Rear Sway Bar with Endlink | zc06_kisstherain | Brakes, Suspension, Chassis | 2 | 05-19-2022 07:26 AM |
| Rear Endlink Bolt | Sikku | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 05-29-2018 04:40 AM |
| Rear lower control arm endlink/shocks ratio adjustments | Brzerker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 01-05-2018 12:05 AM |
| HIC ROOF Spoiler$100/TRD REAR bumper rep$100/slightly bent Raven hood $100 | VakaGT | Exterior Parts (Aero, Lighting, Etc.) | 16 | 07-11-2016 01:49 AM |
| Bent rear suspension - advice needed | Etomatoeman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 12-20-2013 12:19 PM |
