Drives: 2016 Subaru BRZ Limited
Catless UEL and OFT Stage 2+..... use o2 spacer?
I have a Megan racing catless uel and tuned with stage 2+ OFT.
The Megan came with an angled o2 spacer so I installed it on the rear o2, but it seems maybe I shouldn’t have since I have the tune? Should I remove the right angle o2 spacer with my setup, and just install the rear o2 sensor without it? |
Wheels for Brains
Up to you. Removing the Rear O2 sensor would probably help preserve it, but as far as the function of the car, the tune probably doesn't even use the readout on the sensor for anything.
| The Following User Says Thank You to EndlessAzure For This Useful Post: | NoHaveMSG (03-11-2020) |
Drives: Bone stock
I took mine out but it doesn't hurt to keep it in. It actually makes your o2 wiring a little longer. Mine is a tight fit without the angeled spacer.
Sent from my SM-N960U using Tapatalk |
| NJ motor vehicle inspection with OFT stage 2 and catless UEL | B-R-Z | NY / NJ / CT / PA | 45 | 06-10-2018 03:46 AM |
| Small spacer vs big spacer | Atomic Rooster | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 11-09-2017 02:30 PM |
| Catless UEL Header - N1 Exhaust - OFT Stage 2 | ripper | Engine, Exhaust, Transmission | 28 | 07-18-2017 07:01 PM |
| Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? | Khorne | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-03-2014 01:53 PM |
| 25mm conversion spacer with 5mm spacer = safe or unsafe? | deedz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-05-2013 12:59 PM |
