Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 02-03-2018, 12:39 PM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
NJ motor vehicle inspection with OFT stage 2 and catless UEL
Hey guys,
I am due for my first inspection this May and am wondering if I have to do a header swap back to stock and/or tune swap back to stock to pass. Any info is appreciated.
Old 02-04-2018, 05:21 AM   #2
LancePower
Drives: 2020 BRZ tS
If your ECU is "ready for test" with no Codes or Pending Codes you should be good with that part of it.
My local MV Inspection Station has the cameras build into the ground, so if they are paying attention that will probably notice the missing CAT.
LancePower is offline   Reply With Quote
Old 02-04-2018, 06:23 AM   #3
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
There's another thread about this floating around and I'm pretty sure the conclusion was that any tune that disables the cat CEL will keep the car from showing full emissioms readiness, thus leaving you unable to pass. I'm not 100% sure about this though and am hoping other more knowledgeable people will chime in.
ApexEight is offline   Reply With Quote
Old 02-04-2018, 11:59 AM   #4
B-R-Z
B-R-Z's Avatar
But the BRZ/FRS has the skid plate so there is really no way to see a missing cat, right?
From what I've read searching around, the OFT tune will still produce a readiness status via OBDII, even with the CEL disabled within the tune. Mostly worried about the sniffer.
Old 02-04-2018, 01:33 PM   #5
ApexEight
If the OFT tunes do indeed show readiness then that would be freakin' awesome. Sucks that you have to do the sniffer, pretty sure we just do OBD hookup in GA.
Old 02-04-2018, 03:21 PM   #6
B-R-Z
B-R-Z's Avatar
I'm honestly not even sure what NJ does, it's been over 5 years since I've been through an inspection. Hopefully there is no sniffer.
Old 02-04-2018, 03:30 PM   #7
brz fred
Drives: 2015 Brz
In nj you just need monitors ready and no current pcm codes. The wheels could be being falling off and car on fire and still pass
2015 BRZ
Perrin Catback | Gruppe-s UEL | Gram Lights 57xtreme | STI Brembos | RCE Super Street-1 Coilovers | Tom's | ECUtek
brz fred is offline   Reply With Quote
Old 02-04-2018, 03:37 PM   #8
B-R-Z
B-R-Z's Avatar
Thanks, brz fred. I used to live in Absecon myself, behind shoprite on Seaside ave.
Old 02-04-2018, 04:29 PM   #9
LancePower
Drives: 2020 BRZ tS
No "sniffer" in NJ.
Old 02-04-2018, 11:49 PM   #10
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i just had NJ inspection done. they only test OBDII whether check engine is on or not.
i also have catless + phantom ESC + OFT.
no problem at all. you'd be fine
Old 02-04-2018, 11:51 PM   #11
B-R-Z
B-R-Z's Avatar
Thank you!!
Old 02-05-2018, 10:19 AM   #12
ApexEight
Wow so your ECU showed full ECU readiness despite the OFT tune disabling the cat efficiency CEL? Gah, I'm getting conflicting information compared to another thread.
Old 02-05-2018, 10:33 AM   #13
zc06_kisstherain
Drives: SWP BRZ
i Think so. i didnt go to DMV to get it inspected since my car is lowered i cannot go over that ramp.
so i paid at shop. no question asked.
i guess no problem at all.
Old 02-06-2018, 05:40 PM   #14
B-R-Z
B-R-Z's Avatar
Oh well yeah that's a different story lol. I am lowered as well but only on ProKit springs so I think I am good for the DMV ramps. Though, I may ask around for local shops and just pay to get it done and not worry about it.
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
Catless UEL Header - N1 Exhaust - OFT Stage 2 ripper Engine, Exhaust, Transmission 28 07-18-2017 06:01 PM
Pa inspection and Catless Header b1gb2olo Engine, Exhaust, Transmission 6 12-09-2015 02:15 PM
Moving to TX: vehicle inspection tokiokun717 Southwest 11 06-08-2013 01:28 AM
