Old 03-04-2020, 09:57 PM   #1
EvolutionRevolution
Drives: SCION FRS 2016
Revving at idle?
When at idle intermittently revs from about .5 - 1k..
any clues what this could be?
Car is a 2016 , about 40K, delicious stg 2 tune (although back to stock header).
EvolutionRevolution is offline   Reply With Quote
Old 03-04-2020, 09:59 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Do you have the ac on?
Old 03-04-2020, 10:00 PM   #3
EvolutionRevolution
I'll look to see if I have the ac on Mr. ac.. That'll do it?
Old 03-04-2020, 10:36 PM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Idle will change as the compressor turns on and off.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-04-2020, 10:51 PM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Lol oddly my rpm drops at idle with the ac on. It goes from 900 to 500 then 2 seconds later it up to 900 -ish. But mines a 2013 and it's an known issue from Subaru, not really a problem but if I recall there is a tbs or whatever it's called from the dealer.
As to your problem it's gotta be the tune. That's something I don't know jack about. Hopefully others would chime in on that.
Old 03-05-2020, 02:27 PM   #6
sukumizu
sukumizu's Avatar
Drives: 6MT '15 BRZ | '89 240sx (sold...)
Had this same issue on my car (no ac. Almost never use it) and it went away after flashing my ECU to stage 1 with the OFT. it's smoother than ever now.
la cocaina is not good for you
ig: sad_fa20
sukumizu is offline   Reply With Quote
Old 03-05-2020, 02:38 PM   #7
The AC doesn't even need to be on. If you have the HVAC dial set to the windshield (or a combo including it) and the fan on the compressor will still kick in even on a heat setting. The compressor kicks on to dry the air for more effective clearing of the windshield.
It is not at all uncommon with low displacement engines it is just a bit more noticeable with these.
Old 03-05-2020, 02:39 PM   #8
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Also worth noting that running the front defogger kicks on/off your AC compressor, which will cause a small RPM surge.
Edit: Tcoat beat me to it!
wolffbite is offline   Reply With Quote
Old 03-12-2020, 11:26 PM   #9
jflogerzi
jflogerzi's Avatar
Do you know if there was an aftermarket header with the Sgt 2 tune? If it was tunes with that and you put the stock header back in that cause weird issues in AFR and causing your idle issues plus others possibly
2013 Series 10 FRS #553
Revving after 10 mins idle from cold start Hayer_86 Scion FR-S / Toyota 86 GT86 General Forum 70 03-05-2020 02:39 PM
RPM Drop when revving? G17BRZ BRZ First-Gen (2012+) — General Topics 16 03-13-2017 08:25 PM
high revving NA engine chuy21 Engine, Exhaust, Transmission 30 09-14-2014 07:33 AM
is it ok to drive without high revving? lionbacker54 BRZ First-Gen (2012+) — General Topics 48 08-07-2013 01:36 PM
Slow revving? Manual car. SprayedBigCube Engine, Exhaust, Transmission 40 07-10-2012 04:13 PM
