Old 03-12-2017, 10:29 PM   #1
G17BRZ
Drives: 2017 BRZ limited performance pack
RPM Drop when revving?
Hi everyone, I'm new here with a 2017 BRZ with PP. I have searched the forums for this but haven't found anything... When I rev up the motor the RPMs will die pretty significantly before revving up, and in other people's videos it doesn't seem to do this. Anyone know whats going on? Heres a video...
G17BRZ is offline   Reply With Quote
Old 03-12-2017, 10:45 PM   #2
radroach
Drives: car
Need to clarify, are you blipping the throttle yourself or is it the engine that is doing that itself? Otherwise I can't tell what the problem is except your not breathing on the throttle enough to rev it up.
Old 03-12-2017, 10:49 PM   #3
G17BRZ
I am blipping the throttle over and over, but each time I tap the gas the Revs seem to drop right before going up
Old 03-12-2017, 10:53 PM   #4
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
If I were the service writer:
Situation normal. Adjust the customer, not the car.
ToySub1946 is offline   Reply With Quote
Old 03-12-2017, 10:59 PM   #5
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Good luck with a lightened flywheel...
dhuang is offline   Reply With Quote
Old 03-12-2017, 11:43 PM   #6
radroach
Drives: car
Well the engine can't just respond in the manner you're asking it. Your opening and closing the throttle shut at low rpms so the engine is trying to breathe and adjust to what you're doing. I think first there has to be some time for pre-enrichment otherwise it'll just be sucking air.
When I rev I do it easily first, and then just breathe into the throttle. I don't tap.
Old 03-12-2017, 11:45 PM   #7
radroach
Drives: car
Then again I could be totally wrong. It's kinda hard to tell what's wrong without seeing what your feet are doing.
Old 03-13-2017, 12:01 AM   #8
G17BRZ
I am just tapping the gas and not allowing he throttle to breathe, just my Z didn't react the same way. It could be completely normal for this car and I could be totally overthinking it. Thank you though!
Old 03-13-2017, 12:09 AM   #9
radroach
Drives: car
@G17BRZ the throttle response should become more refined through normal and spririted driving. If your car is brand new or the battery disconnected recently then the car takes time to re-learn, and can be laggy in the duration.
Old 03-13-2017, 12:13 AM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
Alltezza (03-13-2017), guybo (03-13-2017)
Old 03-13-2017, 12:14 AM   #11
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Your Z probably had rev hang which is something you don't want in a car cuz it will mess with your timing on rev match.
Just a guess cuz I don't really know what the problem is from the video lol!
krayzie is offline   Reply With Quote
Old 03-13-2017, 06:08 AM   #12
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
So the complaint is that when you let up on on the gas, the revs drop? Am i missing something?
The Following User Says Thank You to guybo For This Useful Post:
~el~jefe~ (03-13-2017)
Old 03-13-2017, 06:09 AM   #13
guybo
Huge E85 fan!
guybo's Avatar
It could be a troll post, the YT video is labeled
Category Comedy
License Standard YouTube License
Old 03-13-2017, 07:05 PM   #14
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
@G17BRZ I believe that is normal. I had the same question when I first got the car but no others seem to understand what I was getting at. I haven't experienced other cars doing this either, this is a first(I know the pre-2017 didn't dip in rpm before it revs)
Sent from my SAMSUNG-SM-G920A using Tapatalk
Oxyg3n is offline   Reply With Quote
brz, idle, rev, rpm
high revving NA engine chuy21 Engine, Exhaust, Transmission 30 09-14-2014 07:33 AM
Slight smell when revving high Jakecrow Issues | Warranty | Recalls / TSB 26 09-07-2014 03:26 PM
Slow Revving / Acceleration after TSB 0040-13 Hardway Issues | Warranty | Recalls / TSB 9 08-25-2014 10:14 AM
is it ok to drive without high revving? lionbacker54 BRZ First-Gen (2012+) — General Topics 48 08-07-2013 01:36 PM
Slow revving? Manual car. SprayedBigCube Engine, Exhaust, Transmission 40 07-10-2012 04:13 PM
