Old 03-03-2020, 08:51 PM   #1
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Koenigsegg Germera - The Practical Family Hypercar
Old 03-03-2020, 08:55 PM   #2
Irace86.2.0
https://www.roadandtrack.com/car-sho...-photos-specs/
The Gemera has a 2.0-liter twin-turbo three-cylinder with 600 horsepower and 442 lb-ft of torque. And it doesn't have camshafts. Yes, this tiny triple uses Koengisegg's remarkable Freevalve technology. This is also a FlexFuel engine designed to run on renewable alcohol. It combines with a hybrid system for an astonishing 1700 horsepower and 2581 lb-ft of torque. Koenigsegg claims it'll hit 62 mph in 1.9 seconds, which is bonkers.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Spuds (03-04-2020)
Old 03-03-2020, 09:12 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i forgot about the freevalve system. it's incredible we haven't seen anything similar yet in any other car.
Old 03-03-2020, 09:16 PM   #4
Lantanafrs2
Drives: 2013 frs red
Most likely way too expensive right now
Old 03-04-2020, 12:42 AM   #5
Irace86.2.0
It would be interesting to see a cost breakdown. The Freevalve system would replace the camshafts, variable valve timing systems and timing belts/chains. The motors would be more compact making packaging easier, crash-safer, etc. weight would likely decrease too.
It could be reliability, as even Koenegsegg wasn’t using Freevalve in all their vehicles. It could be the cost to license the technology. It could be the cost in general, but then again, I would imagine it existing on luxury cars or supercars by now.
Old 03-04-2020, 01:38 AM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
While freevalve is really friggin cool, there are quite a few expensive challenges to overcome when implementing it.
One is that air is compressible. Being a pneumatic system acting against pretty stiff springs, you need VERY high pressures. On an engine. All engines develop leaks due to vibration and temperature changes, and other factors I'm not going to get into.
Second is that air has mass, momentum, and is not a solid. Meaning one end of a column of air only reacts as fast as the pressure wave from the other end can reach it (this is technically also true for solids, but the speed of sound in solids can be quite high). The fun part is the speed of sound changes with temperature and other such factors. This can be mitigated with small distances, but less space means smaller components, in turn decreasing the amount of pressure that can be applied.
Third is air can be humid or dusty with interesting effects on small electronics. How pure does that air need to be?
There are a few more, but I'm sure you got the point. I'm a bit skeptical it's ready for primetime, but if anyone could pull it off, the mad scientist that is Koenigsegg is he.
Old 03-05-2020, 09:17 PM   #7
soundman98
soundman98's Avatar
they said in the video they're working with "an AI company from texas" to control the freevalve system, it's just that complex.
Old 03-05-2020, 10:06 PM   #8
serialk11r
Drives: '06 AM V8V Coupe
Did anyone catch the part where he said it can run as a two stroke at some speeds? That's a really great use of camless valve actuation, being able to switch from two to four stroke. Imagine you're gunning it, and suddenly the exhaust note goes up an octave in pitch, then back down XD
Old 03-11-2020, 03:59 PM   #9
Irace86.2.0
Old 02-07-2022, 12:07 AM   #10
Irace86.2.0
Koenigsegg's Tiny Electric Motor Makes 335 HP and 443 LB-FT of Torque
Dubbed the Quark, the motor weighs just 63 pounds.
If they can get batteries smaller, lighter and more powerful, it will be the end of ICEs. Imagine a Miata with one of these up front and a small battery pack.
The Following 5 Users Say Thank You to Irace86.2.0 For This Useful Post:
NoHaveMSG (02-07-2022), PulsarBeeerz (02-07-2022), Red-86 (02-07-2022), Stonehorsw (02-07-2022), Teseo (02-21-2022)
Old 02-07-2022, 09:26 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Or a kit to replace the clutch with this setup so you have a hybrid like the OnPoint/MPP 350Z.
https://www.mountainpassperformance....350z-overview/
The Following User Says Thank You to NoHaveMSG For This Useful Post:
soundman98 (02-07-2022)
Old 02-07-2022, 10:57 PM   #12
Irace86.2.0
Really, at that point, the engine is just a range extender and a noise maker. Why replace a more, power-dense motor with a less, power-dense engine? I would put a motorcycle engine that revs to 15k if I was to put a engine in the car to make a hybrid.
A VQ37 weighs 430 pounds. For 441 pounds, you could have 7 of these motors. That is 2,345 hp and 3,101 tq, if the math was additive. The engine is just not needed in any way except for noise and range.
Old 02-07-2022, 11:15 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
But will you have the battery to run it?
Old 02-07-2022, 11:19 PM   #14
soundman98
soundman98's Avatar
yep, something that small, put it right between the motor and trans. regen braking, and electric power boost!
Is it practical for me to get a BRZ/Fr-S Weston_Perini Scion FR-S / Toyota 86 GT86 General Forum 45 06-27-2017 01:51 PM
Supercar vs. Hypercar Joakim3 Other Vehicles & General Automotive Discussions 0 01-12-2016 04:41 PM
Such a nice practical family car! Khyron686 Scion FR-S / Toyota 86 GT86 General Forum 37 08-02-2015 06:05 PM
Your Dream Hypercar - Post a Pic! JPxM0Dz Other Vehicles & General Automotive Discussions 50 02-21-2014 06:21 AM
OK, the car has been out for a while- is the car practical? D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 58 08-27-2013 11:11 PM
