Old 03-01-2020, 11:24 PM   #1
coconutboy
coconutboy's Avatar
Drives: 2015 White BRZ Aozora
Catless + Q300 = Decent daily?
Hi peeps,
Big question. Here's my setup and you tell me what you think:
1) 1320 UEL catless headers
2) 1320 overpipe
3) high flow catless front pipe
4) Stock midpipe
5) Dual resonator custom axleback
I want something with less drone. Driving around in earplugs is embarrassing. (Very sensitive ears)
My buddy can sell me his Q300 for a good deal, but will it help the drone? Heard really good things for the Q300, drone is the biggest thing.
I doubt it does pops and bangs but if it does than I'm buying it 100%.
Thoughts?
Sent from my SM-G950W using Tapatalk
coconutboy is offline   Reply With Quote
Old 03-01-2020, 11:37 PM   #2
kev0
Drives: '14
Does your custom axleback have mufflers? If so, the Q300 probably won't be much quieter.
You can go back to a stock front pipe to soften the noise a bit, as a high-flow cat doesn't really do much anyways..
kev0 is offline   Reply With Quote
The Following User Says Thank You to kev0 For This Useful Post:
coconutboy (03-01-2020)
Old 03-01-2020, 11:41 PM   #3
coconutboy
coconutboy's Avatar
Hi Kev
No it's just 2 magnaflow resonators.
Old 03-01-2020, 11:52 PM   #4
kev0
Drives: '14
Ah, okay that's damn near a straight pipe almost. Yes a Q300 would make it a lot quieter!
coconutboy (03-02-2020)
Old 03-02-2020, 01:06 AM   #5
86MLR
86MLR's Avatar
Just weld in 2 resonators in your current frontpipe.
Doesn't cost alot, and will reduce drone more than a Q300 ever could.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 03-02-2020, 01:14 AM   #6
Joveen
Joveen's Avatar
Drives: Bone stock
Get a custom midpipe with nice resonator or muffler
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 03-02-2020, 01:32 AM   #7
86MLR
86MLR's Avatar
He is using the OEM midpipe which has a resonator.
His issue is drone from UEL and no cats, the front pipe can easily be fixed by adding in a couple of resinators, that "should" kill the drone, then if required, he needs to look at mufflers to knock down the volume.
https://www.cjponyparts.com/resource...-vs-resonators
Old 03-02-2020, 01:39 AM   #8
Joveen
Joveen's Avatar
Drives: Bone stock
But stock still bottlenecks the system.
Old 03-02-2020, 04:06 AM   #9
86MLR
86MLR's Avatar
Not if it's NA, and not that far down the pipe where the exhaust gases have cooled, alot, thus reducing volume.
When I was playing NA the only real restriction I found was the 2 cats.
The smaller OEM midpipe back exhaust size may actually aid in keeping the exhaust gas velocity.
Maybe????
Fluid dynamics is cool, and magical, like unicorns....maybe magical unicorn exhaust science.
All we need is a RPM, exhaust size and temp at the overpipe, exhaust size and temp at the midpipe and lots of math which I will not attempt.......because stupid.
The Following User Says Thank You to 86MLR For This Useful Post:
NoHaveMSG (03-03-2020)
Old 03-02-2020, 01:43 PM   #10
coconutboy
coconutboy's Avatar
Thanks for the replies.
Honestly I think I'll still do q300 instead of experimenting with resonators.
I am confident it will reduce drone based on a lot of digging.
Old 03-02-2020, 03:27 PM   #11
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've ran completely stock catback with no cats, header and test pipe. It droned very badly and made horrible sounds. I doubt it will reduce the drone much if you insist on no sound deadening in your front pipe.
Intent > Content
Old 03-02-2020, 04:27 PM   #12
coconutboy
coconutboy's Avatar
Hmm... I've heard otherwise.
However I'll give it a shot, and if it's still as bad as you've experienced I'll explore other avenues.
Old 03-02-2020, 05:30 PM   #13
solidONE
solidONE's Avatar
Worse come to worse , you can just slap on some resonators later. Plus quality of exhaust sounds can be somewhat subjective. Some people think the sound of tin cans vibrating against each other sounds good.
If you think about the location of the front pipe it makes sense. you have something smack dab in the middle vs at the very end of the entire length of the exhaust. which placement of the (smack dab, or at the very end) do you suppose would have a bigger effect on reducing total vibrations or changing the frequency or amplitude? Good thing is that Q300 probably sound 10 time better than the OE chambered muffler.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Old 03-02-2020, 06:29 PM   #14
coconutboy
coconutboy's Avatar
That's great info dude. Appreciate it
My ''decent'' daily 86 adrianfrs Member's Car Journals 8 06-08-2016 04:22 PM
Q300 and Berk Catless FP -- Socal xcooperx Engine, Exhaust, Bolt-Ons 1 08-14-2015 04:57 PM
Invidia Q300 + Full catless set up raspy? BRZPDX Engine, Exhaust, Transmission 14 02-25-2014 12:29 PM
Brz invidia q300 catless startup andrew5826 BRZ Photos, Videos, Wallpapers, Gallery Forum 9 10-14-2013 06:22 PM
Invidia q300 and catless front pipe Dipstik-sportech Engine, Exhaust, Bolt-Ons 9 10-06-2013 12:32 PM
