Old 03-01-2020, 02:17 PM   #1
StraightOuttaCanadaEh
Wes
Silly question about painting engine bay caps
So I've been wanting to paint the oil/brake fluid/coolant and windshield washer fluid caps. Obviously they'll need to be off for a few hours, which leaves them open to the elements. Any precautions to take here? Particularly concerned about the brake fluid
Instagram: @gt86ws
Old 03-01-2020, 02:28 PM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
latex gloves and some rubber bands do alot in the way of giving peace of mind
if you are broke boy like me then just stuff a blue shop towel in them ( clean) and call it good.
Clutch Dog is offline   Reply With Quote
The Following 2 Users Say Thank You to Clutch Dog For This Useful Post:
korhun (03-02-2020), StraightOuttaCanadaEh (03-01-2020)
Old 03-01-2020, 02:35 PM   #3
Wes
thank you. There is no danger of getting air into them or messing with the vacuum, regarding the brake fluid and coolant in particular?
Instagram: @gt86ws
Old 03-01-2020, 02:41 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I just covered the open things with painters tape. The only risk with having the caps off is contamination from something falling in
Ignore the Grimmspeed pulley cover. I took it off after because it wouldn't fit right. Everything else is painted red with red plasti-dip
The Following User Says Thank You to DarkPira7e For This Useful Post:
Old 03-01-2020, 02:42 PM   #5
Clutch Dog
thats not how the brake fluid or coolant works.
brake fluid is based on pressure, you dont want air bubbles in the line. keep the fluid open to air wouldnt introduce bubbles in an already bled system
coolant has a natural high point in the system that allows hot air to expand and vent off to, thats how we get a coolant overflow. which should be outside the radiator.
iw ouldnt worry about it and just glove it up
The Following User Says Thank You to Clutch Dog For This Useful Post:
Old 03-01-2020, 02:52 PM   #6
ls1ac
ls1ac's Avatar
If you are really being carful, rubber band a plastic bag over the brake reservoir.
Brake fluid is hydroscopic and a plastic bag will help to stop the fluid from absorbing water from the air. That is why there is no vent in the cap.
Also be carful of the paint you pick as brake fluid will dissolve many paints if it comes in contact.
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
StraightOuttaCanadaEh (03-01-2020), SuperTom (03-02-2020)
Old 03-01-2020, 03:09 PM   #7
Wes
Lovely, thank you gentlemen
Instagram: @gt86ws
Old 03-01-2020, 03:14 PM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
Feel sorry for the poor mechanic... Colour coding, H&S and everything that he studied pissed down the pan..
Old 03-01-2020, 05:31 PM   #9
Wes
haha good thing my mechanic knows this car like the back of my hand. I start my sentence and he finishes it
Instagram: @gt86ws
Old 03-01-2020, 08:48 PM   #10
Clutch Dog
paint will eat anything... even flesh
also is that a noble M600 <3
Old 03-02-2020, 01:23 PM   #11
ls1ac
ls1ac's Avatar
No it is the track version of the M400.
Old 03-02-2020, 01:29 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I used plastic wrap from my kitchen to cover the reservoirs. I cleaned my caps with solvent several times, sprayed them with adhesion promoter, paint, then clear. They turned out nice.
I LIKE TIRES!
StraightOuttaCanadaEh (03-02-2020)
Old 03-02-2020, 02:01 PM   #13
Wes
That’s what I was thinking of using as well!
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Leonardo (03-02-2020)
First time with OFT (silly question) tzbang Software Tuning 3 06-18-2016 09:34 PM
Silly question about a wastegate. els7x5 Forced Induction 5 12-21-2015 10:01 AM
silly newbie e85 question 2much Engine, Exhaust, Transmission 3 01-19-2015 05:34 PM
Silly question but....using WRX under-seat sub in the BRZ? Chauntalei Electronics | Audio | NAV | Infotainment 5 04-15-2014 12:05 AM
Plasti-dip or painting the fluid caps in the engine bay Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 8 09-07-2012 03:03 PM
