Drives: Black FR-S
Silly question about a wastegate.
I have just done my first turbo (fully installed now) and there is a wastegate with a short pipe leading off of it. I bought the kit used and the guy didn't have the original shortened front pipe from the kit so I had one made. My question is if that pipe off of the wastegate should lead back into the exhaust or just end and kind of dump everything out? Let me know before I asphyxiate in my car and take the environment with me. Thanks!
tl:dr Should the wastegate lead back into the exhaust? |
Little Member
Drives: Bloo - The 13' BRZ
So it can route back into the exhaust and most systems will do this. You can also, if you like ridiculously loud "screamer pipes", leave it as is. Normally best for that pipe to be routed outside of the engine bay in a way it won't vent to the cabin, for whichever route you choose to take. Its some peoples style, but I personally recommend against it for the reasons of sound and gasses in the engine bay and cabin.
Not Bаnned Anymore
Drives: Heavily Modified FRS
^ what he said, route it back into the exhaust, keep it classy
Drives: Black FR-S
For real, I have been getting fumigated. It sounds like a diesel but I am happy to hear it doesn't hurt anything until I can get it fixed.
Drives: Late 2014 Subaru BRZ
Ya as a dump pipe when at max boost settings, the car is loud and can get cops looking. It's up to you. If you do have it recirculate in to you exhaust make sure exhaust is big enough and doesn't cause back pressure on your wastegate. It will make your turbo spool slower.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
Drives: 2013 FR-S, HKS V2 S/C
cut hole in hood
point dump towards sky
| External Wastegate Question | TurboBRZ | Forced Induction | 23 | 07-22-2015 12:38 PM |
| silly newbie e85 question | 2much | Engine, Exhaust, Transmission | 3 | 01-19-2015 05:34 PM |
| Silly question but....using WRX under-seat sub in the BRZ? | Chauntalei | Electronics | Audio | NAV | Infotainment | 5 | 04-15-2014 12:05 AM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Silly question about the dash... | jm1681 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 13 | 09-11-2012 01:20 PM |
