Old 02-24-2020, 04:59 AM   #1
ClevelandFRS
ClevelandFRS's Avatar
Drives: Scion FRS 2013
My 2013 FRS has a knocking sound but only in low speed
My 2013 FRS in automatic (71k miles) has a knocking sound that only appears when the gas pedal is pressed and only under maybe 30mph or so. A gentle press on the pedal will start the sound after about 1-2 seconds and it will stay there until I either let off, or press down more.
I am of course going to have it looked at as soon as I can. But, was curious what the community might think off the top of their head and with experience in this model on what that could probably be.
This sound stops as soon as I let off the pedal or exceed roughly 30mph. Some advice is appreciated if you happened to have any idea of what this is. Could is likely be the Vacuum Pump that needs to be replaced?
ClevelandFRS is offline   Reply With Quote
Old 02-24-2020, 05:11 AM   #2
tomm.brz
Drives: brz 2017 hksv2
probably clutch/bearing, it always goes bad and makes crunchy sound
but you should do a video and try to catch it
Old 02-24-2020, 05:27 AM   #3
ClevelandFRS
Here is a link to a short video I just made that showcases the sound problem. I caught a P0441 error code and failed the echeck, service center said to replace the gas cap first and drive it a bit. If that doesnt make the checkengine go away, then I need to replace another part for that.
I got the FRS back, heard this issue which I never had before coming from it, the knocking sound.
[ame]https://www.youtube.com/watch?v=VDENqxcqTPM[/ame]
Old 02-24-2020, 06:07 AM   #4
tomm.brz
ok, not clutch, haven't expected that sound actually... no idea sorry
Old 02-24-2020, 08:34 AM   #5
Brake booster pump on the AT cars. It is not an uncommon issue really.
You can wade through the wild guesses in this thread but the pump will most likely be it.
http://www.ft86club.com/forums/showthread.php?p=2447589
Old 02-24-2020, 02:59 PM   #6
ClevelandFRS
Vacuum pump was my guess. Well, at least it wont be super expensive if that is the issue. Sigh...
The Following User Says Thank You to ClevelandFRS For This Useful Post:
Tcoat (02-24-2020)
Old 02-24-2020, 06:13 PM   #7
norcalpb
norcalpb's Avatar
Is it that Jetsons space ship noise?
Old 02-25-2020, 10:37 AM   #8
ClevelandFRS
Not helpful.
Old 02-25-2020, 10:43 AM   #9
Originally Posted by ClevelandFRS View Post
Not helpful.
I think he is referring to the "crickets" which although a perfectly reasonable question is a whole different noise than the booster pump.
Old 02-25-2020, 03:23 PM   #10
norcalpb
norcalpb's Avatar
Not helpful.
I was actually just inquiring into your problem but it sounds like you got it all figured out.
Maybe when you have a problem that happens at “low speeds only”, take a video that’s not you idling in park?
Old 02-25-2020, 04:29 PM   #11
ClevelandFRS
No need. The problem was the vacuum hose. It was completely disconnected. The sound is the same idling and also driving, it wouldn't have made a difference.
Anyway, the problem was corrected and its gone now. Lets hope it stays gone.
Old 02-25-2020, 11:14 PM   #12
jflogerzi
jflogerzi's Avatar
Thanks for posting the solution as others will appreciate it when searching
2013 Series 10 FRS #553
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 08:09 PM
Got a clunk/ knocking sound help please bryansuriel3 Engine, Exhaust, Transmission 8 01-01-2018 02:05 AM
knocking sound wingrider Engine, Exhaust, Transmission 12 08-22-2016 12:35 AM
Knocking sound from AC? DCdesign2000 Issues | Warranty | Recalls / TSB 2 09-25-2015 09:09 PM
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 09:58 PM
