Old 02-16-2020, 10:25 AM   #1
Kuang
Drives: 2019 BRZ - Sport Tech RS
Question VALENTI REVERSE BRAKE LIGHT
Hello,
Does anyone know a good video to follow when I am installing my valenti 4th reverse brake light?
Kuang is offline   Reply With Quote
Old 02-16-2020, 03:16 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
This one's pretty good.
[ame]https://www.youtube.com/watch?v=6_6hGc1A3Tk[/ame]
The Following User Says Thank You to x808drifter For This Useful Post:
soundman98 (02-18-2020)
Old 02-16-2020, 08:47 PM   #3
StraightOuttaCanadaEh
Wes
Originally Posted by Kuang View Post
Hello,
I went to Apex Auto in Markham and told them exactly what I wanted (triangle lights up with brake - does not blink 3 times - V on at night) and they re-pinned it for me
Instagram: @gt86ws
Old 02-16-2020, 10:58 PM   #4
Kuang
oh damn okay, how much they charge?
Old 02-17-2020, 09:38 AM   #5
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I just tapped into the stock reverse harness and for the brakes I tapped into my driver side tail light.
Clueless
YamahaR86 is offline   Reply With Quote
Old 02-18-2020, 08:19 PM   #6
Suparu
Drives: 2013 BRZ Limited
I followed this one, just the 4th brake light part
Suparu is offline   Reply With Quote
Old 02-19-2020, 10:14 PM   #7
Polyline
Polyline's Avatar
Drives: 2018 Subaru BRZ Sport-tech RS
check for the functionality of the brake lights. i've seen some sets where the brake light only lights up if the V has power. if this is the case, you can get around it using 2 diodes in-line.
Polyline is offline   Reply With Quote
Old 02-19-2020, 11:09 PM   #8
Wes
It wasn’t much. Like $50?
Instagram: @gt86ws
Old 02-20-2020, 12:50 AM   #9
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Check out: http://www.ft86club.com/forums/showthread.php?t=124363
Elliotw is offline   Reply With Quote
Old 02-20-2020, 06:48 PM   #10
edwardl
Drives: 2018 BRZ
This is what I used. I had to resolder the wires inside the light itself though to make it light up the way i want it. The brake doesnt pulse though it just lights solid
edwardl is offline   Reply With Quote
Old 02-27-2020, 07:29 PM   #11
Suparu
What were you trying to do with the soldering, get rid of the pulsing?
I wish only my V lit up when lights were on. But the V + the part that pulses both light up when lights are on.
Old 02-27-2020, 08:47 PM   #12
edwardl
Drives: 2018 BRZ
I rewired it so the V stays on when the headlights are on then when I hit the brake the triangle comes on. Sadly the wiring that claims to keep the pulse doesn't always work so I had to do it a different way and it doesn't pulse. But at lease they're separate
Old 02-29-2020, 06:45 PM   #13
Suparu
I wish mine did exactly what you were shooting for too. It would’ve been perfect if they wired it to do that. Only the V comes on when headlights are on, then when brakes are applied you get that little triangle pulse and the triangle only stays on until brakes are let off.
I thought I wired mine wrong when I saw the triangle stayed on with the V when headlights were on.
Old 02-29-2020, 07:23 PM   #14
kev0
Drives: '14
I know a guy selling harnesses that doesn't require you to cut off and repin wires to get the 4th brake light to work. He sells it for $23 each. PM me if you want link to his FB sales post.
kev0 is offline   Reply With Quote
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
[HELP] Valenti Reverse Fog/Brake light Tallented DIY (Do-It-Yourself) Guides 0 12-17-2017 12:45 AM
FS: Valenti Sequential tail lights, Reverse/brake light: SOLD!!! turbotention Exterior Parts (Aero, Lighting, Etc.) 6 12-09-2017 08:47 PM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 06:51 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
