Old 02-14-2020, 04:00 PM   #1
PurpleSpaceShip
PurpleSpaceShip's Avatar
Drives: GT86
OFT Caliberation, can not find file for it
So I hooked up my OFT and did Read. it was successful and resulted in Calibration code: ZA1J700J
Website has nothing for that. I found on these forums saying that's an old calibration some rev dip bug that is fixed at dealerships.
So should I just flash original tune and update my ECU or is there a way without all that hassle.
My cars idle is fine by the way.
PurpleSpaceShip is offline   Reply With Quote
Old 02-14-2020, 04:41 PM   #2
hifiguy99
Drives: 19' Toyota 86 TRD
Are you trying to flash an OFT off the shelf tune? If so, yes you can update to ZA1JA01J with the OFT. Flashing the ZA1JA01J off the shelf rom from OFT's website will be the same as updating the ECU through the dealer and then flashing the OFT rom. Otherwise if you don't want the off the shelf tune but would like to just update the ECU with the latest tune you can go to this thread to get the ZA1JA01J rom
http://www.ft86club.com/forums/showthread.php?t=62332
Someone correct me if I am wrong
hifiguy99 is offline   Reply With Quote
Old 02-14-2020, 05:21 PM   #3
steve99
https://support.openflashtablet.com/...3-ks-6mt-v4-03
BIN FILE TO XML FILE? Nobunnyhere.86 Software Tuning 3 10-06-2017 08:46 PM
tuning file John27 Software Tuning 3 04-22-2017 02:23 PM
2017 86/brz ecu def file available? Chr15 Software Tuning 6 11-24-2016 11:23 PM
OFT - Mode file not found. Cannot create a tuning file. focobrz Software Tuning 11 07-17-2015 10:22 PM
which OFT map file to use? BPB stg2 Corradooo Software Tuning 2 06-29-2014 05:09 PM
