Old 06-29-2014, 01:30 PM   #1
Corradooo
Corradooo's Avatar
Drives: Storm trooper FRS
which OFT map file to use? BPB stg2
I tried searching but couldnt find anything... also skimmed around for a while and googled and came up empty, if this has been covered before I appologize, but before I bother the guys at vishnu with a call or email or message I figured I'd post here first.
I just picked up my OFT yesterday, and I have the stage 2 UEL map on now, But I have crawford power blocks in the car, and want to run the BPB map. i downloaded the maps, but there is 6 different files for 91 octane stg 2 listed 700c,900c, a00c, a01c, b00c, and b01c. how do I know which one of these to load?
Corradooo is offline   Reply With Quote
Old 06-29-2014, 03:41 PM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
It should show you your CAL ID in OpenFlash Manager under any of the tabs. Regardless I believe the OFT actually doesn't allow you to upload a file with a mismatched CAL ID. It can also be found when plugged into your car under Information.
zkv476 is offline   Reply With Quote
Old 06-29-2014, 04:09 PM   #3
Corradooo
Corradooo's Avatar
Thanks, I appreciate it!
[review]Stay away from Ecutek FA20 tune(stg2) if..... WatchmaN Engine, Exhaust, Transmission 46 06-06-2014 04:57 PM
File Repository? rupert Site Announcements / Questions / Issues 1 01-08-2014 03:46 PM
Visconti Tuning now has STG1 & STG2 Tunes - More Info Inside! Visconti Software Tuning 19 07-20-2013 05:35 PM
FT-86 STG2 Brake Kit VS Wilwood 4R Slotted Front jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-10-2013 07:33 PM
usb mp4 file format wrohdejr Electronics | Audio | NAV | Infotainment 1 04-16-2013 07:19 PM
