Old 04-22-2017, 12:34 PM   #1
John27
Drives: scion fr-s
tuning file
when you rest the ecu of the car does the tuning file get affected in any way ?
John27 is offline   Reply With Quote
Old 04-22-2017, 01:00 PM   #2
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
I presume you meant "reset" instead of "rest." If so, when you reset the ECU (typically by removing power from the car for an extended period of time) the fuelling trims learned by the ECU are reset. Other learned values are also reset.
The base code for any given map is not affected by power loss to the ECU.
theadmiral976 is offline   Reply With Quote
Old 04-22-2017, 01:06 PM   #3
theadmiral976
I just saw your other post about cleaning the MAF sensor resulting in a perceived loss of power. I presume you are trying to troubleshoot this by resetting the ECM. You can certainly try resetting the ECM - it won't hurt anything. My advice to you; however, is that immediately following the reset, turn the car on and don't move it for 60 seconds. If you immediately drive away following a hard reset, you can force the car into a limp mode as it hasn't had time to set a fuelling trim baseline. Limp modes make the car accelerate sluggishly and can take some time (dozens of miles of driving at various RPMs) to reset. If you let the car adjust to idle timing, your chances of going into a limp mode setting are reduced.
Old 04-22-2017, 01:23 PM   #4
John27
Drives: scion fr-s
okay ty
2017 86/brz ecu def file available? Chr15 Software Tuning 6 11-24-2016 10:23 PM
OFT - Can't Load Tuning File BRZBuzz Software Tuning 0 07-18-2015 08:04 PM
OFT - Mode file not found. Cannot create a tuning file. focobrz Software Tuning 11 07-17-2015 09:22 PM
which OFT map file to use? BPB stg2 Corradooo Software Tuning 2 06-29-2014 04:09 PM
File Repository? rupert Site Announcements / Questions / Issues 1 01-08-2014 03:46 PM
