Drives: Scion FRS
Mid pipe to reduce drone
Hi
Picked up a used nameless axelback exhaust. 2.5 inch inlet and 4inch mufflers. Been used total around 15,000km. It sounds really good outside the car and growls like a wolf but there’s drone in the car around 1500-2000rpm. Rest of the exhaust is stock. Would changing the stock mid pipe to something else with a bigger/better resonator reduce the drone in the cabin? Would you recommend anything else? I don’t plan to add anything else to the exhaust. I only really drive city so if anything I’d like to push the drone to higher rpm Thanks |
Drives: Bone stock
Get a resonated midpipe that fits the axleback (Nameless resonated midpioe)
Sent from my SM-N960U using Tapatalk |
The stock mid pipe is resonated. I would recommend adding a better resonator to the stock FP if possible. I remember when I had that axleback with the stock header it was boomy and droned
2013 Series 10 FRS #553
Drives: 2013 Subaru BRZ
Get the Nameless FP/OP Catted and Resonated. It cut pretty much all the drone from my setup which only came back after I installed a header lol. I might be selling mine if you're interested.
[ame="https://www.youtube.com/watch?v=IW9tddJLios"]This is what my setup sounded like on the stock header.[/ame] |
| FS: 2.5" Venturi Inserts $12 tone down drone (catless, straight pipe, muffler delete) | neilvosko | Engine, Exhaust, Bolt-Ons | 12 | 02-06-2017 11:31 AM |
| Catback to reduce rasp from HFC Front Pipe? | Sh1FTy | Engine, Exhaust, Transmission | 2 | 06-24-2016 01:17 PM |
| Which frontpipe to reduce drone? | edeekeos | Engine, Exhaust, Transmission | 14 | 04-28-2016 02:36 PM |
| Quarter wave resonator installed to reduce drone, it works! | boomslang | Engine, Exhaust, Transmission | 2 | 09-20-2015 05:52 PM |
| Top hat spacers to reduce NVH? | swarb | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 02-04-2015 07:52 PM |
