Old 09-20-2015, 03:06 PM   #1
boomslang
Drives: Toyota
Quarter wave resonator installed to reduce drone, it works!
I've got a full P-Tuning 3" exhaust and P-Tuning 4-1 header installed.
I had a Random Tech cat welded in the front pipe in an effort to quiet it down a bit as well as reduce the exhaust smell. Even with the cat welded in, the drone was a bit much for me.
So I had my buddy weld in an adjustable quarter wave resonator. I have a PST carbon fiber driveshaft, which gave me much more room to work with over have the factory 2-piece driveshaft taking up space.
I used a Burns Stainless super tight radius 2.5" elbow welded into a 2.63" OD straight. The 14" long end cap is a 2.5" straight with the flat cap welded on it.
I have a Torca stainless clamp to keep the end cap assembly from blowing off.
This combo gives me an adjustment range of about 29" OAL to almost 40" OAL if I need it. I do have a small bracket welded in place to help support the end of the 2.63" OD straight section.
I adjusted it to 32" OAL and it kills the drone by probably 80%! My ears don't hurt anymore after driving the car.
All the guides online about quarter wave resonators are based on theory. Your best bet is to installed the biggest diameter one you can fit and make it adjustable so you can tweak it. I plan on adjusting mine more to kill the drone as much as possible.
boomslang is offline   Reply With Quote
Old 09-20-2015, 04:50 PM   #2
boomslang
Drives: Toyota
One more pic from the back with natural lighting.
Old 09-20-2015, 05:52 PM   #3
DJCarbine
Thupercharged
DJCarbine's Avatar
I had a pre-made helmholtz resonator on my test pipe, I had similar results to you with an Invidia N1 and a UEL header. Drone city without the resonator.
2013 FRS
Vortech V3 11psi
does the perrin catback with NO resonator drone at all? pr086 Engine, Exhaust, Transmission 28 05-23-2018 04:02 PM
Which frontpipe to reduce drone? edeekeos Engine, Exhaust, Transmission 14 04-28-2016 02:36 PM
DIY - Killing Drone - 1/4 or Branch Resonator BRZ.PTY DIY (Do-It-Yourself) Guides 9 01-08-2015 08:05 AM
Ideal resonator placement to remove drone on muffler deletes? CaptainSlow Engine, Exhaust, Transmission 22 05-20-2013 09:34 AM
