Old 02-10-2020, 04:26 PM   #1
Inteze
Drives: Toyota GT86
Clicking Noise in the rear area while Coasting
Hey guys,
I am very desperate, nobody seems to find the issue and I can’t find a thread discussing this problem etc.
SEE VIDEO :
So basically, in my Propshaft / Differential area, there is a “clicking” noise who appears while coasting, as soon as I press the Gas Pedal it stops immediately. It also occurs while downshifting and letting of the clutch (not rev-matching), 3 rapid clicks...
Checked :
- CV Joint are good
- Axle Nut has been changed
- Differential Mounts seem to be noisy, and one of the mounts bolt was little bit bent, but wasn’t replaced for now
Thinking :
- Maybe loose/broken propshaft ?
- Loose Differential mounts
- Broken Differential
All help would be great, please help me solve this myserti!
Thank you!
SEE VIDEO :
Inteze is offline   Reply With Quote
Clicking noise from the rear Seiryuu Issues | Warranty | Recalls / TSB 18 05-17-2020 08:07 PM
Clicking Noise in the rear area while Coasting Inteze Engine, Exhaust, Transmission 10 04-09-2020 01:04 PM
Clicking Noise From Rear Axle TSB Bach415 Issues | Warranty | Recalls / TSB 0 09-16-2019 04:43 PM
Clicking / Ticking Rear Noise shellslinger Issues | Warranty | Recalls / TSB 19 07-20-2017 09:40 PM
Clicking noise in wheel area, driver side Rabbit of Caerbonnog Issues | Warranty | Recalls / TSB 19 02-18-2015 01:59 PM
