Old 02-10-2020, 08:00 AM   #1
Inteze
Drives: Toyota GT86
Clicking Noise in the rear area while Coasting
Hey guys,
I am very desperate, nobody seems to find the issue and I can’t find a thread discussing this problem etc.
SEE VIDEO :
So basically, in my Propshaft / Differential area, there is a “clicking” noise who appears while coasting, as soon as I press the Gas Pedal it stops immediately. It also occurs while downshifting and letting of the clutch (not rev-matching), 3 rapid clicks...
Checked :
- CV Joint are good
- Axle Nut has been changed
- Differential Mounts seem to be noisy, and one of the mounts bolt was little bit bent, but wasn’t replaced for now
Thinking :
- Maybe loose/broken propshaft ?
- Loose Differential mounts
- Broken Differential
All help would be great, please help me solve this myserti!
Thank you!
SEE VIDEO :
Inteze is offline   Reply With Quote
Old 02-10-2020, 08:06 AM   #2
j_ros94
Drives: 2017 Subaru BRZ
Originally Posted by Inteze View Post
Hey guys,
SEE VIDEO : https://www.youtube.com/watch?v=osPt...ature=youtu.be
Checked :
- CV Joint are good
Thinking :
Thank you!
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 02-10-2020, 01:44 PM   #3
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Hey guys,
Checked :
- CV Joint are good
Thinking :
Thank you!
Both links are dead unfortunately.
JBezugs is offline   Reply With Quote
Old 02-10-2020, 03:33 PM   #4
Inteze
Drives: Toyota GT86
Oh sorry here is the good one : [ame]https://www.youtube.com/watch?v=fg2iJpSptoY[/ame]
Old 02-14-2020, 02:55 PM   #5
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
I feel like we could better answer your question if we knew basics like, what year, mods done, mileage... DD or track car, etc.
Does this video harmonize with your problem? [ame]https://www.youtube.com/watch?v=KwoMUejhs_Q[/ame]
ROFL it's Waffle is offline   Reply With Quote
Old 02-14-2020, 08:45 PM   #6
norcalpb
norcalpb's Avatar
Could be the U joints on the drive shaft. There are 3 of them.
Old 02-15-2020, 03:29 PM   #7
Inteze
Drives: Toyota GT86
No it’s not that noise.
2013, coils, 55.000km
Old 02-15-2020, 03:29 PM   #8
Inteze
Drives: Toyota GT86
Starting to think that it’s the U-Joint, indeed...
Old 02-15-2020, 08:30 PM   #9
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I thought your car was a 17 and up form the taillights... So no warranty coverage.
Are you 100% certain its not the CV joint? I removed my clicking axle at maybe about 60K miles-ish and removed the boot. The grease was completely liquified. It pored out like it was oil, not grease.
A 2013 lowered 86 with a bad original axle is no surprise to me. Even expected. Just throwing that out there.
Intent > Content
The Following 3 Users Say Thank You to solidONE For This Useful Post:
Opie (02-17-2020), ROFL it's Waffle (02-17-2020), Tcoat (02-17-2020)
Old 02-17-2020, 07:36 AM   #10
ROFL it's Waffle
I am also thinking CV joint, and the reason it's not clicking more is just because you lifted it up and are putting only rotational stress on the CV joint, not rotational and tire/road resistance. Sounds like you just need to re-grease the joint and inspect the boot for cracks, replace if necessary (not in that order lol).
The Following User Says Thank You to ROFL it's Waffle For This Useful Post:
solidONE (02-19-2020)
Old 04-09-2020, 01:04 PM   #11
Inteze
Drives: Toyota GT86
Little update :
CV Joint broke, Axle had to be replaced everything fine now
clicking, differential, noise, propshaft, rear
Clicking noise from the rear Seiryuu Issues | Warranty | Recalls / TSB 18 05-17-2020 08:07 PM
Clicking Noise From Rear Axle TSB Bach415 Issues | Warranty | Recalls / TSB 0 09-16-2019 04:43 PM
Clicking / Ticking Rear Noise shellslinger Issues | Warranty | Recalls / TSB 19 07-20-2017 09:40 PM
clicking noise from drivers side rear CARBONGT86 CANADA 11 08-23-2015 06:58 PM
Clicking noise in wheel area, driver side Rabbit of Caerbonnog Issues | Warranty | Recalls / TSB 19 02-18-2015 01:59 PM
