Old 01-28-2020, 09:29 PM   #1
Suparu
Drives: 2013 BRZ Limited
Part # for MY17 window switches?
I have a 2013 BRZ and recently installed climate controls from a 2017+, with the different knobs and glossy carbon fiber look. I did it along with replacing the silver plastic with JDM tS black plastic and the leather w/ red stitching bits that started coming on the MY17 models.
The 2017+ BRZ’s have matching window switches that have the glossy carbon fiber look. Does anyone know that part #?
I checked some sites but none of them show actual pics, so I’d probably end up ordering the usual ones I already have.
Suparu is offline   Reply With Quote
Old 01-28-2020, 10:36 PM   #2
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
If nobody gets you the number try calling Subaru parts and having them figure out the OE part number. Tell them you wanna price it out or whatever. Just make sure to use the vehicle info from the original car. Get the official Subaru part number and then it will be easier to seek a hot deal on the world wide web.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following User Says Thank You to ActionMaxon For This Useful Post:
Suparu (01-29-2020)
Old 01-29-2020, 11:10 PM   #3
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Try LeeC parts, they’ll probably have them for you. If not, partsouq is my go to for looking up OEM part numbers/diagrams by model year
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
The Following User Says Thank You to the new guy For This Useful Post:
Suparu (02-01-2020)
Old 02-01-2020, 05:15 PM   #4
Suparu
I ended up buying them for $99 including shipping, used off eBay. The listing said they came off a 2018 BRZ tS but they’re in mint condition and the buttons feel like they’ve never been used before.
Sometimes ya get lucky on eBay, sometimes you get garbage. This time it paid off.
Old 02-01-2020, 05:38 PM   #5
MaverickMonk
Drives: 13 BRZ Limited
LeeC parts is the jam, got my window and hvac switches from them as well as some other random stuff.
Pro-tip, sticking a few squares of sound deadening on the flat parts of the unit, and some felt tape on all the mounting points will get rid of the hollow sound/feel caused by echo/vibration in the unit. Gives it that nice luxury feel. Unless 2oz of weight is too much to add of course
MaverickMonk is offline   Reply With Quote
The Following User Says Thank You to MaverickMonk For This Useful Post:
Suparu (02-01-2020)
Old 02-01-2020, 08:02 PM   #6
Suparu
Thanks for the pro-tip, I’m gonna do that. The bass rattle of my switches is annoying.
So when you say to use felt tape on the mounting points, should it just go around the 3 spots the bolts go (the square tabs)?
Window switches, Airbag module, Sparco seat mounts, recaro slider Joesurf79 Interior Parts (Incl. Lighting) 12 11-29-2018 11:41 AM
MY17 Black trim traction control buttons part no. Trap63 DIY (Do-It-Yourself) Guides 8 11-25-2016 10:43 PM
HVAC and window door switches white LED swap phanguy Interior Parts (Incl. Lighting) 4 04-17-2014 04:58 PM
Window switches not working right after battery swap jonbonazza Issues | Warranty | Recalls / TSB 9 01-10-2014 02:50 PM
Bass Rattles Driver Side Window Switches.... jadewbj Issues | Warranty | Recalls / TSB 14 05-19-2013 12:42 PM
